Uncommanded acceleration in 4L
Fly2Win
Chalfont, PA
F250 SD, 68 Firebird, 85 300ZX
I did my first real off-road day with my 6 week old Bronco at the Anthracite Outdoor Adventure Area in PA coal country. Me and 4 Jeeps hit a bunch of green trails.
The Bronco is amazing and performed well throughout the day. However, there were a half dozen times when I experienced an uncommanded acceleration.
I have a Black Diamond 2.7 Auto, 2D, SASQ, MID Bronco.
While running through the woods on mild rock trails (softball or smaller sized rough mining debris with the occasional slab to set a wheel on) in 4L and in D (not M1 or M2) at just a couple MPH, I would let off the accelerator to let the engine slow me down, and it felt like I had hit the gas pedal. Enough so that I quickly stabbed the brake pedal to stop it.
Has anyone else experienced this? I feel like it is controllable but is a bit of a surprise when it happens.
‘21OBX
90Bronco19
2022 bronco outer banks
You didn’t hit the trail cruise button did you? It will keep you going.
Fly2Win
Fly2Win
Chalfont, PA
No, That was off. Good question, though. That was the first thing I checked.
dgorsett
colorado
F250, Mustang, Explorer
My bronco doesn't do it, but my f250 does when in 4L first gear headed downhill. It seems like it's trying to burn off fuel loading up on a steep down grade. It actually will go slower downhill in second M mode.
Merc4x4
steve
Maybe it shifted up a gear or two on you? Which GOAT mode were you in?
I've been using M&R and RC modes to take advantage of transmission/throttle/steering tuning you can't set manually. I could see the transmission up-shifting in Normal mode for better fuel economy vs holding gears longer in Sport/Sand/Rock Crawl.
AK SNO RIDER
Ty
Alaska
If it wasn't trail control ny guess would be it was shifting. You know that "kick" the trans does when slowing to the stop on the 2-1 shift? If it was doing that in low range it would be extra noticeable.
Fly2Win
Fly2Win
Chalfont, PA
Hmmm, I was in Normal mode. It could have been a shift now that you mention it. Hard to tell sometimes. I’ll try RC and turn off the rear locker next time. Thx.
kevin.gt
Kevin
Canton, GA
This 👆 It's happened to me in 4L Normal and I'm pretty sure it was an unexpected upshift. Makes sense too. Down hill, picks up speed increasing rpm, triggers an upshift
Fly2Win
Fly2Win
Chalfont, PA
Yes, I have felt that. First stop pulling out of work is a little downhill and I sometimes feel it lurch a little forwards. I can see where it would be more pronounced in 4L.
AZMikeL
AZ
2022 Bronco Badlands 4dr, 2016 BMW 435i
I recall this happening a time or 2 in 4L as well. Can't recall if I had it in Manual mode or not though. I'll try to remember to test it out next time I'm in 4L.
darkscion0
Canada
2021 Badlands Sasquatch
I posted about this before but I've experienced something similar. The shift from 1st to 2nd can be really jarring, to the point that I shift up manually when offroading.
SeldomSeen
Jay
Boulder, Colorado
google
Yes. Just started new thread.
Tom
St. George, UT
2022 Bronco Wildtrak, 2017 Toyota Tacoma Off Road
This has happened to me several times. Sometimes it happens when it is shifting but it has happened a couple times when it is in first gear and not shifting. A bit concerning. I have always been going down something steep when it has happened.
