UGH! MIC Top cracking
Derby
Earlier I tried some 303 Aerospace Protectant on my Bronco flare to good effect. Maybe I'll try some around the small cracking area of my hardtop. If I can keep any water from wicking into the cracks, that could go a long way towards avoiding rot/freeze damage.
I wouldn't put anything on it, it may void the warranty.
Acadist
Acadist
WA
2023 BadSquatch
Just took my rack off prior to taking it in for inspection, it has been in for oil changes with the rack on and they didn’t say anything. My cracks were on the back between the hinges for the glass. I believe it’s from the stress of opening/closing the window. I recommend getting a case number from Ford prior to having it inspected.
Derby
I took mine in with the roof rack on, lol I didn't realize it was an issue. I had to loan the mechanic the torque wrench that came with the rack for them to remove. They didn't say anything about the rack.
I am now worried that the minor separation and fraying that led to the replacement will lead to a cracked top. @34k now on a 5/22 build.
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
new here.....just ordered a 2025 with the hardtop, does anyone treat their hardtops to help with cracking ? I so what are my options ? sincerely and thanks for the suggestions ! :beer:
J-Lugster
Ancaster, Ontario
2024 Ford Bronco Wildtrak 4Dr Oxford White
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Thanks to the forum, I became aware of the MIC hard top issues. Looked at four used Broncos on the lot and all had, at the very least, a wavy top where it was starting to bubble. Almost all were in the rear section.
Someone asked earlier and no one answered but if the painted hard tops are not having the same issue, I'd push to have Ford replace it with one of those, especially if you've been back more than once for a replacement top. Hell, I might even pay the difference (at Ford's cost, not retail), just to avoid the hassle even though we shouldn't have to.
Dude1967
Billy
2025 Ford F150 Tremor
Ford where you at? We have questions....
PetePerkins
Pete
TN
2024 Black Diamond
'24 Bronco here. Purchase in March. Checked my top yesterday 12/03/2024 and confirmed that there are visible waves on the removable panels and a crack at the panel just under the side rear glass. I also posted on the other new thread. I have 18k miles on my truck amd will more than likely wait it out another 10k miles or so before bringing it in. Seems a replacement will not solve the issue. My question is, how bad will it get? Will it eventually completely delaminate and fail? @Ford what's up??
Ford Bronco UGH! MIC Top cracking Screenshot_20241203-203048_Gallery
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Only here to point out the "Ford" you're trying to tag isn't Ford. I'm sure the usual bot will be by shortly to congratulate you on your new '24 tho
Rydfree
Benny
Alabama
I took my '23 2dr badlands in Monday to finally have the top replaced. I haven't really been in any hurry since I've heard several have gone through multiple replacements. Was hoping after 3 years Ford would have this shit figured out by now. Picked it up yesterday and was focused on the headliner they did not put in but when finally pulled it outside this top if FAR WORSE than the one I had. The whole thing is honeycombed and wavy. I have pics but they are on my home PC. Looks terrible :(
They promptly ordered a new top, but time is money and I could have not wasted 2 of my off days driving back and forth for nothing.
Shadowsquatch
GA
Cactus Grey 2-Door Wildtrak
Does the Ford extended warranty cover the hardtop issue also, or just the original base warranty? I’ve noticed some cracking on mine also.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
I believe the hard top is excluded from the extended warranty.. so limiited to just the original 3/36
Ducati1098
No, it does not.
