Two Winch wiring diagram
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
… I am in the process of adding a winch too just one through
You didn’t mention $$ But I found Egis they supply marine and emergency vehicle modifiers/ companies
I am using a manual switch, but they offer a remote switch (and a dual switch) all rated @ 500amp
They all come with a 10mm post and deep enough to help connect your 2, 2/0 awg wiring…
Fords Warn winch is directly negative connected to battery, your two wiring should be able to connect to that bus … one on top of & one below. I would use 90* neg cable ends to help manage space.
Would be interested who’s 500 fuse you are using?
Egis for details
https://www.egismobile.com/xd-series
Egis change their small size sales to distributors
https://www.waytekwire.com/search?query=Egis
No need to add another bus.
Haven't bought the fuses yet, but I have this on my list https://a.co/d/3akno28
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
Thanks for all the feedback, here is a revised diagram
changes:
- added bus bars
- moved 500a fuse so its after the isolator
- smaller wire gauge in engine bay
Ford Bronco Two Winch wiring diagram Screenshot from 2025-12-16 20-14-35
No idea where im going to fit the bus bars, but that is a different problem.
I’ve seen someone had a nice bracket that goes over top the battery.
Over top the fuse panel is ok but it needs to be mobile if you go there — there is room in the fender there to tuck it, and that’s a nice spot.
Up by the firewall by the brake booster is a nice spot too, but a bit further from the battery
Bschurr
NY
I was hoping to not have to pop the hood to turn on the winches, is there a down side to using the aux switch as the cut off?
As noted - No downside as long as you are using something (Aux, relay, switch etc) to energize the winch because most are simply hard wired to the battery and can be powered without a key. And, since we are digressing to catastrophic incidents, a front end collision or event that could create a short on the hot wire could be problematic if it’s always energized. I am out of Aux switches so I installed a manual switch under the hood to turn on the winch.
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
most of the good spots are already taken up 😄
https://www.bronco6g.com/forum/thre...-your-bronco-today-👨🏻‍🔧🧰🚿🛠.18089/post-2555947
https://www.bronco6g.com/forum/thre...-your-bronco-today-👨🏻‍🔧🧰🚿🛠.18089/post-2556118
SierraBronco
Regardless of method between relay and manual switch, either is better than how most run their winches. Assuming the power is off.
OP I got a tray from American adventure labs that tucks up by the firewall and holds a square distribution block nicely. For the grounds I put them next to the fender on the supporting structure. Adhesion promoter and quality 3M double sided tape will hold those without issue.
Ford Bronco Two Winch wiring diagram IMG_4137
Ford Bronco Two Winch wiring diagram IMG_4140
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
yup I got the same one but using it for aux switch rewiring
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
some preliminary wiring done
Ford Bronco Two Winch wiring diagram PXL_20251222_032432398
Ford Bronco Two Winch wiring diagram PXL_20251222_191318167
Ford Bronco Two Winch wiring diagram PXL_20251222_210149444
Ford Bronco Two Winch wiring diagram PXL_20251223_003848048
Ford Bronco Two Winch wiring diagram PXL_20251223_004506156
only odd thing I ran into was the battery lug didn't make good contact with the terminal so I added a copper washer (which is just a lug trimmed up, here is a photo for reference
Ford Bronco Two Winch wiring diagram PXL_20251223_004521046
SierraBronco
Is that an ANL fuse?
jsoa
jsoa
Jose
Delaware
2024 Bronco 4dr
SierraBronco
it is yeah
It’s probably fine, just check your specs and AIC. In a worst case scenario the factory battery might be able to exceed the AIC on some of the ANL fuses sized appropriately for a winch.
GI_Jo_Nathan
Jonathan
Just a heads up I'm running a very similar fuse for my two winches. Blew a fuse for no reason a little over a year in. I think the fuse just got tired or something. I replaced it with a much pricier Blue Sea Systems fuse and it's been good ever since.
SierraBronco
I just looked up the specs-AIC isn’t listed and no UL certifications listed either. Personally, I’d get rid of it.
GI_Jo_Nathan
Jonathan
Well that's iteresting... 🤔
Still have the original spare. Maybe I'll swap it in and keep the Blue Sea one as a spare.
Sometimes fuses just go bad - there is a reason most things switched to resettable circuit breakers.
But cheap Chinese fuses seem to go bad a lot more often than decent ones.
