Turbo inlet duct appears collapsed
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Wonder if it has to do with sound? Maybe it going straight from air box causes more noise at some RPM and the turn before the other turbo muffles it. 🤷‍♂️
Tricky Dick
Dick
PNW
www.TD-Distributing.com
That's actually a fairly good possibility. Ford has a history of making some goofy looking intakes trying to get the sound dialed in.
BottleShark
TJ
East Texas
I would bet that an aftermarket intake would wake up the turbo sound a good bit.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Rjhoefar
Rjhoefar
Roy
2022 bronco badlands
Cool, how much
gwbigdog
Guy
OVERGAARD, AZ
jeep
Today the dealer stared it's fine. That how they are. Others on the lot are the same
23OBX2.7
AB Canada
2023 Bronco
The ones with 147 recalls this year?
Haha that's procurement, vendor audits and csuite accountability.....it's almost seems engineered to deliver tax and loss benefits with cash rebates from vendors etc and getting folks into dealer to upsell them.
Regardless the third party oversight is certainly diligent.
Techun
Pa
BD, 2.7, MIC, 4dr
That's mostly quality ($) not actual design. I don't think there have been any/many that are actually design changes...though there are a lot to remember.
drewski
Greenville
2018 Ford Mustang, 2007 Toyota Tundra
Chat GPT is your friend.
In twin-turbo engines (like the 2.7L or 3.5L EcoBoost), the turbos sit on opposite sides of the engine.
  • The driver-side turbo has a relatively straight path to the intercooler or throttle body.
  • The passenger-side turbo usually sits farther from that common junction point.
To make sure both turbos deliver air evenly, engineers design the passenger-side tube with a twist, curve, or longer path to balance:
  • Airflow volume
  • Pressure drop
  • Timing of the airflow pulse
That twist helps ensure both turbos feed the engine evenly and that one side doesn’t create a lean or rich imbalance.
ScottyC
Rome NY
2022 Bronco 4 door
It's Ford's version of the Turbulent Jet system found in the new Chrysler engines.....lol
gwbigdog
Guy
OVERGAARD, AZ
jeep
Ford states, normal by design̈. Same across all models with the turbos. 1 day and 300 miles to find this out. 1200 miles on a new 2.7.
