Turbo Lag
Blaven
Pennsylvania
I must be doing it all wrong. I try to beat my current best of 17.3 mpg in economy mode when I'm driving mine 🤷‍♂️😆
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
I dont know if its just wishful thinking or what, but I feel like if I feather it just a tiny bit before I romp on it, it wakes it up much quicker than just pinning it down does. I love driving my 2Dr. I think it hauls ass in traffic, on the Interstate, etc and I can pass anyone very quickly.
AK SNO RIDER
Ty
Alaska
If you're cutting it so close that turbo lag makes the difference between a crash and not, you're probably cutting it too close.
That or just learn how to drive a turbo. Practice situational awareness and building boost before you need it.
If you think the Bronco is bad, you should try driving a 6.0 with an aftermarket turbo and a hot tune. Better get in to the boost a full zip code before you need it 🤣
Been daily driving turbos for years and NEVER had an issue because of lag. And I'm a more aggressive driver than most.
I've been rather impressed with the responsiveness of the 2.7 in the Bronco. There is some torque management built in compared to the F150, pretty noticeable if you've driven both, but I really have no complaints. It's a 4x4 suv not a sports car
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I think it's mainly the electronic throttle lag that your noticing, not actual turbo lag. People like sport mode because it increasesthe pedal sensitivity.
You can try addinga throttle boosterif you don't want to keep it in sport mode.
-First world problems
Ehh, there is a lag, There are times when im driving around and give it some gas i'll hear the BOV then i press the gas again and there is a lag where nothing happens then i see the boost then it takes off
ProdigyJKU
Rob
2012 Wrangler
Your example proves nothing. The longer the throttle takes to open, the longer it takes to see the boost go up. So if your throttle is delayed, your boost will be delayed regardless of actual turbo lag. You can still feel this delay in vehicle response even when the turbo is spooled up.
There is obvious some turbo lag in ecoboost engines, but Ford's throttle delay exacerbates it, making the lag much more apparent to the driver.
This video should help explain it.
1975U15
2019 F-350 SD, 1975 Bronco
You need more Sport in your life OP.
Ford Bronco Turbo Lag 1643860394062
hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
I run my ranger in sport mode all the time and it helps with the lag.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Can't go wrong with either the 50 state legal calibration from Whipple which we run on our Bronco or the JB4 device which we tested on another first edition yesterday. Both will improve throttle response and provide a considerable increase in HP/TQ over the factory calibration.
Here's a link to the Whipple testing we did and a great review by a customer of ours who runs the JB4 unit. The video we did on the JB4 yesterday will be released in the next few days. I'll make sure to reply with it in here once it's done being edited and live on our YT channel.
If you have any questions in the meantime please feel free to give us a call.
Thanks!
https://www.bronco6g.com/forum/thre...rmance-review-on-bronco-2-door-wt-2-7l.33733/
buzpro
Binky
Tacoma
LethalPerformance
Jared
South Florida
I have the 2.7. It is the first turbo I’ve owned. I am used to a V8 and V6 supercharged.
The 2.7 is plenty strong, etc..no complaints. My only concern is the turbo lag in situations where I need to hurry up and get out of the way.
I’m having to always second guess whether or not to, “make that move” to go around someone for fear of the turbo lag making such a move a, “close call .”
As a result, my driving strategy has changed in heavy interstate traffic. I don’t have the confidence to switch lanes, etc.. Also I have less confidence to pull out from a dead stop into traffic.
I suppose it’s something you have to adjust to with this engine. Sport mode may make it better, problem is, I don’t think it is practical to stay in sport mode all the time.
Any advice from experienced ecoboost/turbo people? I realize driving a V8, etc.. are options, however, other than the turbo lag, I love the engine. I plan to drive my Bronco for a long time (unless Ford ever produces a V8 Bronco-not holding my breath).
We picked up over a half a second on our 2.7L First Edition with the Whipple calibration. Stock was mid 7 second 0-60 and tuned was 6.99. That's a pretty good improvement for a vehicle of this sizer and weight from just a tune.
We also tested the JB4 unit on a friends 2.7L first edition and with Map 3 93 octane we also picked up over half of a second on 0-60 times. Stock was mid 7 seconds while in Map 3 we were able to get down to 6.97 0-60. That's also after running the truck multiple times stock, Map 1, Map 2 and Map 3 with no cool down.
Feel free to reach out if you have any questions about either of these products and we'll be glad to assist you.
Thanks!
LethalPerformance
Jared
South Florida
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
If you find yourself worrying about ”turbo lag” and feeling unsafe in a vehicle that makes 300HP/400TQ I question what you daily drive and how you do that..
kbobber
Kevin
Tiburon, CA
VW Touareg & Atlas
Thanks!
I just added the Pedal Commander to my 2.7L Badlands! This will take care of your throttle response and add some serious pop to throttle response! https://pedalcommander.com/products...co-2021-2-3l-2-7l?_pos=2&_sid=44a37f325&_ss=r
