Turbo boost lost
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Press on the skinny pedal on the right, boost with increase.
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
If your boost really was too low, the ECU would set a code P2099 for underboost and illuminate the check engine light. If that hasn't happened, everything is probably working as intended.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
The 2.7 does not boost much just driving around. Put it in Baja mode and 2H and floor it. You’ll see the numbers go up.
Aaron james
Aaron james
Aaron
New york
2022 ford bronco badlands 4 door
I’ll get a better video of me stepping on it I used to barely touch the gas and my boost gage would shoot up and now I barely hit 13 I used to get around 16-22 , tge turbo noise has died down a bit a friend told me my catalac converter is on its way out idk yet
Dmorty217
Derek
Venice FL
Camery
As I accelerate it slowly goes down
where would I have to check for loose connections
On the charge pipes and intercooler. It’s hard to see the psi in the video. Put the pedal to the floor and if you’re getting 14-16 psi in normal there isn’t a problem. I had a bad blow off valve and there was zero turbo, the bronco would barely drive/accelerate. I drove home 90 miles on the highway with no turbo boost. You would be throwing a code if there was a problem. Get a pedal commander type product, makes a huge difference in the throttle response.
