2.7L stock boost levels
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
when i had the dealer mannequin for a few days i saw 18-19 when i passed someone
JeebusCripes
Mn
ā€˜94 M998, ā€˜89 Wrangler
I’m only seeing upwards of 3-5 psi on my dash. Doesn’t matter the situation. I hardly ever see psi register. Something has to be wrong with my setup.
Jazer
Jessica
2.7 OBX
Pretty sure it's around 18-19 peak, but Im usually not that focused on the readout if I'm goosing it, lol.
Something is definitely wrong if you are only seeing 3-5 psi.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
You might be stuck in "limp-mode"...If the engine sees something out of spec, but not detrimental, it will cut boost to keep things safe.
My Subaru did this one time when I unplugged the Passenger Airbag (track day) and it sensed a problem with the safety system.
Try disconnecting the battery for a few minutes to clear the OBD codes and let the computer reset. That usually takes care of things. Otherwise you may have a boost leak that will be covered under warranty.
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
X2 I'm seeing the same
Ground_zero298
Scs michigan
Sounds like the valves not working right. Common issue. Best to swing by the dealer and tell them your truck only makes 3-5 psi at wot. They should be able to track it down from there.
