CVF boost piping opinions
Gluestick
Josh
Nashville
instagram.com
Explorer ST, Bronco Badsquatch
Passenger side looks easy to get to, but how hard was driver side?
Gluestick
Josh
Nashville
instagram.com
I've been running the CVF for about the last 30k+ miles with the Whipple IC. I like them except now that I have added the bigger turbos I do have occasional problems with the clamp joints blowing apart at max boost. I would still recommend them.
so which clamp joints are giving you problems? I’m assuming you’re using the t-bolt spring loaded ones ?
SCB FabWorx
Aledo, TX
2018 Cadillac CTS V
It's not fun but it's doable. It's easier if you take the tire off unless you have a lift kit. I have a 2" lift and I managed to keep the tire on. The worst part is you have to take the belt off of the a/c compressor and loosen up the bolts to get to one little bolt that holds the turbo oil deliver tube to the block. I recommend lots of patience and long 1/4" drive socket extensions with swivels to get to the coolant and oil tubes feeding the turbos.
I replaced both turbos in about 12 hours, 26 beers and a couple of gallons of sweat YMMV.
SCB FabWorx
Aledo, TX
2018 Cadillac CTS V
Yes the T-bolt clamps with springs. I purchased the same style clamps without the spring and I am slowly replacing the repeat offenders.
Gluestick
Josh
Nashville
instagram.com
SCB FabWorx
Aledo, TX
2018 Cadillac CTS V
That's them. The places that blow apart are where two straight runs couple together like on top of the engine discharge from the driver side turbo and the bigger pipe in front of the engine going to the intercooler (the most difficult SOB to get to). It takes them a couple of months to work their way apart. I can usually catch the top one before it blows but the other one is really hard to see.
