Tricky Dick's Dirty Bronco
Status
Not open for further replies.
LockedBronco
Frank
PA
1972 Bronco
Are you having them do it?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Tricky Dick
Dick
PNW
Assembly was going too smoothly until I went to tighten the top nuts. Stripped out the knurls holding the studs in, then trashed the threads trying to hold the stud and get the nut off.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20230211_190920601
Tricky Dick
Dick
PNW
Next time drill a 1/8 hole in the nut and use a center punch to split the nut.
I wanted to save the nuts because I have a spare top hat but no spare nuts. So right now tack welded the studs in and waiting for paint to dry.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Your cheaper than me lol
Tricky Dick
Dick
PNW
The nuts didn't want to go back on anyway so I ended up using the ones that came with the spacer kit (which I only used the rear spacers).
I didn't take fender to ground measurements before tearing it apart, anyone else want to share theirs?
kodiakisland
Arkansas
Fender to ground measurents are useless to determine amount of lift. Fender to center axle measurements compare lifts and take tire/wheel/psi variables out of the equation. With the Icons I’m at 26 inches front, 27 inches rear.
And it should be metal fender and not flare as people have different flares or flare deletes.
Tricky Dick
Dick
PNW
Brain fart, you're right. I'm at 25" in the rear with the spacers and stock coilovers. Front is only half done so I can't measure yet.
Tricky Dick
Dick
PNW
Beer break!
This is full droop, but it looks like I'll have no tire to UCA/knuckle clearance issues with the so called 37x14.5s.
Level Up tie rod nuts, Icon tubular UCA, and EXP with V6 coils at the tallest setting.
Ford Bronco Tricky Dick's Dirty Bronco PXL_20230211_225111637
Status
