Transmission skid plate installed
TXBronco1313
Did you replace the deflector with this? My brand new Heritage has a stone deflector so I’m looking to get a transmission skid plate as well
bkfit
bkfit
BK
Spaceship
Back in 21 I added a Aeroskin deflector. If that’s what you’re talking about. Definitely recommend getting a trans skid plate to button it up plastic pan takes a hit on the trail no Bueno.​
TXBronco1313
Yeah my heritage edition came with a stock rock deflector type of plate under the passenger side but I'm not a fan of how exposed the transmission pan is.. Will def look into getting one
contented
Karl
Central Fl
BMW M2 Competition
Did that too. Great folks to work with.
Ford Bronco Transmission skid plate installed IMG_2253
Ford Bronco Transmission skid plate installed IMG_2269
Midnight_Blue
Jeremiah
Los Angeles
There might be a reason Ford offers skids for everything under the Bronco EXCEPT the transmission. I doubt it’s because the Ford engineers forgot about the transmission.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Yeah, its called "Dealer Value Added" which is slang for the the "dealer to make money when you snag it on a rock and its not covered under warranty".
bkfit
bkfit
BK
Spaceship
When you snag or hit the “plastic pan”
Callelk
Larry
Idaho
Midnight_Blue
Jeremiah
Los Angeles
I’m pretty sure it’s called heat dissipation. You probably don’t want your tranny overheating on the way to Starbucks.
  • Wow
Reactions: 0ne
kevin.gt
Kevin
Canton, GA
FWIW, I’ve had a Asfir’s transmission skid for nearly 2 years. Trans temps have been fine on and off road, including trails in Utah in July and summers in GA. I think you’ll be fine idling the Starbucks drive-thru
Mike T
Brandon SD
2023 Ford Bronco
I’d say that closed & protected the Trans & cats real nice.
It looks like it bolts right up with the factory steel skid plats. Did you have to modify anything? Looks good. Thought you where losing ground clearance but after looking at the pictures its only about the thickness of the metal skid and it close to the angled cross member bars that seem to get bent easily an. Also does the sway bar disconnect work ok with this?
Willhunt4food
Nashville, Georgia
1969 Firebird; 1981 CJ7; 1990 K5; 2007 Z71
Needs coverage over the transmission cross braces. They seem to get hit a lot. The LOD covers all of it and works with the factory skid plates
Ford Bronco Transmission skid plate installed IMG_8365
Ford Bronco Transmission skid plate installed IMG_6862
