Transmission fill tool
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
$8 bucks at Harbor Freight.
Pump oil/gas from your vehicle and inflate equipment with the same transfer pump.
Ford Bronco Transmission fill tool pum
Bonnie & Clyde
Cory
Carson Valley NV
2024 Two door Big Bend Sasquatch Azure Gray
I just did a tranny service on mine and used this $8 pump to get 6.3 qts out of my pan before dropping the pan. Worked great. I just fed the hose into the fill hole as far as possible and sucked it out.
Nc211
Washington DC
The Ford tool and the Motive container in this picture when I did the pan swap last September. I greatly appreciated the ability to hang the tool on the transmission with no worries of it falling out while using the pressurized tank to release the new fluid into the transmission. Worked perfectly, no problems. Agree the tool is obnoxiously expensive for what it is though, but not sure anything else that isn't a full "U" end would hang on the transmission as well hands free? I didn't have a lot of confidence in the end pieces that came with the Motive container like I did with the actual Ford tool. I didn't try them.
DIY lesson I learned a long time ago to save your garage floors. Buy a cheap washing machine pan from the store. Has saved many garage floors for me over the last 20+ years.
Ford Bronco Transmission fill tool IMG_4581
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
Ducati1098
Do you have the Ford special tube with it or just the one that came with this?
I'm getting ready to do a pan swap & refill & want to make sure I'm set up to be able to do regular trans fluid changes moving forward...
Just the hook end that comes with it works perfect
Ducati1098
@jtgensler that powerfill tool only adds fluid though, it wont remove it. Just making sure you know that.
jtgensler
Jamison
Clarion, PA
yeah. I'm swapping the pan out to the PPE one, so I'll have a drain plug moving forward & I'll probably just use a tote when I remove the OEM pan to try to contain the mess.
Murraydog11
Rick
