Trans Gear Display
MPZ
Everglades
Albuquerque, NM
2024 Bronco
Everglades
Does anyone know if there is a way to have the gear you are in always appear on the cluster panel? Obviously the gear shows up for a few seconds if you manually change gears while in Drive, but I was hoping to get it to display at all times.
Batson35
Ohio
Black Diamond 4Dr & Badlands @ Dr
Gotta be a forscan tweak for that
  • Like
Reactions: MPZ
Go_UL_Cards
Wyatt
The Villages, FL
2024 4 Door Soft-top
Many have tried, all have failed. I went thru every thing i could try in the 'easy to read text version'. Turned them all on - gear position never shows up except in manual mode for a few seconds.
  • Like
Reactions: MPZ
MPZ
MPZ
Everglades
Albuquerque, NM
2024 Bronco
Everglades
Thank you all for your replies.
Does anyone have issues with the 2.3 L auto down shifting when coasting down a hill? That’s gets on my nerves so bad.
HeliPilot
Kenny
CT
2022 2.7L SAS
My raptor shows the gear in the middle of the tach. I’m willing to bet that the new digital cluster does the same.
Ducati1098
Nope. Only the Braptor cluster unfortunately
shadowfax
Central Coast California
While it's not the center cluster, I have a Banks iDash that I run while offroading. It'll show me both selected and actual gear positions, along with the plethora of other readouts.
  • Like
Reactions: MPZ
joes bronco
Gordon
post falls Idaho
2021 bronco 2017 f150
I have the scangauge 111 and it does show what gear your in with the 10 speed auto. The scangauge has 3 pages with up to 9 selections on each page. This unit will display about anything that's in the bronco's computer system
Chrome_Pony
Chrome
The Great Land
Where did you mount it?
dgorsett
colorado
F250, Mustang, Explorer
I guess I like it to downshift. Holds back without using brakes. It is even more aggressive on downhill downshifts in Sport Mode, good for mountain driving
