tool to remove wipers?
rret
rick
ct
frontier, jetta
can anyone recommend a tool to remove the wipers? something that is actually known to work? ('car' is a Bronco base.) Thanks.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’ve been considering a rear wiper delete and curious on what that entails…
GreyZ
Gulf South Louisiana
For the front or rear? For the fronts you should be able to remove the nut and then a good tap with a db mallet on the hinge location should pop it off.
any part store should be able to rent the puller, but in my experience I havenever needed one.
rret
rick
ct
frontier, jetta
yeah that didn't work on my Bronco. The arms are super tight. Can anyone recommend a puller that actually works (fits down in there too)? I'd even buy a Ford tool but can't find that either.
Moto26
Tucson AZ
I was looking at this recently, too. I haven’t pulled the trigger, but it seems you need something like this…
https://www.amazon.com/OTUAYAUTO-Battery-Terminal-Wiper-Puller/dp/B076PY8785/ref=sr_1_13?crid=RPTBWDYL0L3R&keywords=2+arm+puller&qid=1683062591&sprefix=2+arm+puller,aps,219&sr=8-13
That’s what I thought, until I tried it. Good luck!
JohnnyBronco
Pennsylania
X4
Try a small battery terminal puller. Or a small pickle wrench, applying upward pressure while you tap the post --and please place a disposable nut back onto the threads before tapping or you may ruin the threads and will be adding a thread chaser to your toolbox.
And don't be in such a hurry, apply WD40 or better liberally overnight
Failing the above if you are replacing the arms with something else then a mini Dremel type or oscillating tool will slice right through the arm you are trashing anyway
CalvinT
Calvin
Phoenix, AZ
Thanks for the answers/suggestions. Ordered this - will see if it works -
https://www.amazon.com/gp/product/B01J2R5ES4/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
Reviving thread because of this. I just bought this puller.
It seems to be the only easily available puller that works for pulling wiper arms. I'm sure Ford has a special tool, but no one has provided information. It's not a perfect fit, but it worked to pop the wiper arms loose. The cowl keeps it from being a perfect fit. Use the narrow jaws.
Mine is super tight too. I had picked up a small puller at autozone that’s similar to that Amazon one and it worked but it not a great fit - it chewed up the metal around the arm a bit and I had to touch up the paint.
CalvinT
Calvin
Phoenix, AZ
The one I used didn't do any damage but it didn't pull evenly. It didn't slip. I read somewhere that the shafts may be tapered. The arms come free once they've been moved a little bit.
