Best Windshield Wipers?
FordMedic
Bill
Ann Arbor
2023 Bronco WildTrak
What are the BEST windshield wipers out there for the Bronco badlands?
CalvinT
Calvin
Phoenix, AZ
Depends on where you live. What's best in Michigan isn't the same as what's best in Phoenix.
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
A few times I made the mistake buying those. Each time they are in the trash inside of 60 days. For most of my vehicles it is Bosch Icon's or bust. But with my Bronco I will stick with OEM. After 1 year of ownership they are still perfect. Zero streaks or chatter.
Tolzer
Gil
Kentucky
2026 Bronco
Choose the Bosch ICON 17A if you want a reliable plug-and-play option that is guaranteed to clip onto your factory arm perfectly, clear smoothly right out of the box, and handle highway wind lift effortlessly.
Choose the PIAA Si-Tech 17" if you are fully committed to the benefits of a silicone blade that continuously applies a hydrophobic film to the glass, but you want an easier, cleaner setup process than what Kimblade offers.
snolen
stan
indiana
78 bronco
not the rain x blades just rain x
Hummell
Adam
Charlotte, NC
I know this one! Check out: 2021 to 2026 PIAA Si-Tech Blade Kit
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Most mechanics will recommend that with any Ford you stick to OEM blades due to the hassles and variability in replacement brand adapters for Ford arms.
Having said that, I really like the cheapo Chinese amazon blades I replaced mine with. Keep in mind, though, that I live where it rarely rains. When it does these work well, though.
https://www.amazon.com/dp/B0DB1NMJTG?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I like the Motorcraft ones the best as well so far.
I have a set of Rain-X on right now, just because I got caught out of town and had one break and needed to replace. I'm not a fan.
CalvinT
Calvin
Phoenix, AZ
I carry spare blades with me. The sun/heat here is hard on blades and they'll go bad just sitting and you won't know until if finally rains. (We get 7 inches a year)
CalvinT
Calvin
Phoenix, AZ
Shouldn't make any difference.
breaddrink
Washington
Nissan's
I agree. I auto swapped to icons, and they judder unless the glass is soaked. OEM was better.
