Replacement windshield wipers recommendations?
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I bought Motorcraft units and they work well.
I do not assume they’re the same as the ones that come on a new Bronco.
MayhemMike
Mercury
If you take some alcohol wipes and run them over the rubber parts of the blades you will remove all sorts of filth and the wipers will last longer.
PMR
Patrick
Dayton, TN
2020 Ford Raptor
Get the Bosch Envisions.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Noticed when the wipers I ordered for the 2 series came in, it's the exact same connection system as on the BMW, threw one of the old Icons on there to verify, fit like a glove
Ford Bronco Replacement windshield wipers recommendations? wiper2
Ford Bronco Replacement windshield wipers recommendations? wiper1
Kyukidoeric
Panama City Beach Florida
2022 Bronco (former 69 & 77 Bronco owner)
Has anyone replaced their wipers yet? If so, what which kind did you go with?
I just got a good set, took the rubber out from the new ones and replaced them back I to the stock wipers. I couldn't find ones that fit, the Ford dealer didn't even stock them yet. So I improvised, and it worked perfectly.
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
I need to find silicone wiper blades. I've always had so much more success and longevity with silicone blades.
AKBronc49
Russ
Anchorage, Alaska
I'm 9,350 miles and a year and a half since ownership and my factory blades are working well. I clean the blades with every wash in the summer and a handful of times in the winter.
BuaidhNoBas
Greenville SC
2023 Wildtrak, 2022 Expedition Timberline
I’m also looking for a silicone replacement. I had a protective film put on my windshield and my detail guy recommends silicone. Anybody know of a silicone blade that will fit?
Merc4x4
steve
NJ
I was happy with the factory blades, so when they wore out (streaking and chattering) I had the dealer service dept replace them when I went in for an oil change and tire rotation.
They work just like new again, lol.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I threw on some Tricos because I wanted to go smaller 15". I did this to reduce the resistance, but I also like the smaller blades - somehow it just looks cooler and as my wife said "utilitarian" ;)
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
….and a little off topic, but a PSA:
If/when you need to remove the wiper arms, you’ll need a two- or three-arm puller.
BuaidhNoBas
Greenville SC
for those interested, I ended up buying these off of Amazon (specifically needed silicone blades due to a protective film):
PEAK Silicone Plus Windshield Wiper Blade, 17-Inch (Pack of 1) https://a.co/d/aGSLwTB
They installed easily with the adapters provided and were a perfect size match for the OEM blades. Haven’t had a chance to put them to use yet but will report back if they suck.
86Isuzu
Buffalo, NY
89 Bronco II, 03 Ranger Level II, 2022 Bronco
I don't know why everyone is saying its a new design blade. Its nothing new.
I bought Bosch Icons last year before delivery (Part# 17OE) and ran them last winter. Pretty disappointing - I run the Bosch on all my vehicles.
I installed Trico Silicone Ceramic (Part# 90-180)early spring this year...meh, they're ok.
I think I'll give the Trico Titans (Part# 10-180) a go next.
RainX Latitudes aren't good enough to wipe my ass.
