Too many decisions!!!
chtucker
Kirkland, WA
FJ Cruiser
I can't make this easy on myself!!! Too many decisions!
Need to level out the front/accommodate winch/mount etc.
Option 1- Level kit. cheap, gets me back to stock height. Doesn't address added weight. Done right now with through a variety of options
Option 2- OME kits, raises everything up .75", addresses added weight, can offset cost by selling SAS suspension
Option 3- New adjustable coilivers (Likely King). SUPER expensive, adjustable to help level out. Look good, eventually want to do all 4, but probably not in the cards with tires, additional skids, and other stuff I want to do. I would do just the front for now.
I don't want to do a perch/collar lift. I am not looking to go more than 1" level kit. Almost all the downsides of a spacer with the additional effort of having to go use a spring compressor somewhere.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Food for thought, while you don't want to do a perch kit, its probably the best bang for your buck at the moment. It will both increase ride height a small amount and add bit of preload to the front springs - artificially addressing the extra weight on the nose... Otherwise you've got your bases covered it seems
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Option 3 would be great, but đź’¸.
I think your best course of action are the OME kits. The Bilstein Sasquatch suspension can help offset the cost.
amazingjason
Jason
CA
1987 Samurai, 1966 442
I ordered a manual 2.3 Sasquatch 2 door big bend with modular bumper and tow and plan to add the winch. Wouldn’t the stock V6 Sasquatch front springs be an ideal swap for both ride height and ride/handling?
Jason
Frankie945
Frank
Louisville KY
Q50
I think if we wait till this time next year or even next spring there will be more options available. The 1.25 perch collar mod does ride nice it feels just like Stock again with the added weight up front I like it for 125$ it’s easy to install and won’t kill your cv’s.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've been having these same internal debates. Every option has it's own set of cons. I decided on Icon EXP shocks and I'm thinking I might run some 4dr V6 coils on them. The coil part of that formula wouldn't help an FE obviously.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Same issue for me. My front is only 1.5" lower than the rear, so I'll probably just roll with it until I want to make a bigger change to 37", if ever.
