Rear Too Stiff
sledboy
2021 Ford Bronco, RZR XP4 Turbo
I have the exact same feeling. The suspension is very jarring 10-30 mph. Have you found any solutions yet besides going full send with Kings or Fox?
Unfortunately we have not. We are still running the stock Bilsteins. I just can't justify spending $4,000+ for shocks. I talked to Fox over 1.5 years ago and they said they were working on something other than their Elite Series shocks. But as far as I know, they have never released them. So we are still waiting and wondering if there will ever be a softer shock solution.
67BroncoG1
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I don’t think it is a shock thing but more of a spring rate issue. On Monday I towed my ski boat which is right at the max tow capacity and the rear suspension hardly sagged. When if finally goes to the dealer someday I’ll complain about it and see what they say.
James Cole
MX
Badlands Sasquatch (hopefully)
Hello guys,
Any updates on this?
My 23 Badlands is pretty stiff at the rear... looking to make it softer.
MrBell
Seattle
Bronco 4 door OBX
2 Door Badlands owner here. The lousy city streets are making for a bouncy, annoying ride. I spoke with the folks at Tire Rack and they said the culprit was the KO2 tires due to their reenforced sidewalls. Anyone swapped out their factory KO2 tires for something else?
sledboy
I really wonder if the folks at Tire Rack are correct. We have KO2s on our Bronco and my son has a Jeep Wrangler Rubicon that also has KO2s of the exact same size. The Bronco has a much firmer and harsher ride. The KO2s may contribute to the harch ride but it is not the cause. It's the shocks!
sledboy
Hello guys,
I got tired of waiting for Fox and started doing more research. I found that the Bilstein 5100 shocks are probably what I want to make the ride softer on rough roads at slow to moderate speeds. I found a deal on them yesterday at Stage 3 Motorsports for $490 and I could not pass them up. I am excited and have high hopes. They will be here tomorrow and hopefully I can get them installed and tested out in the next couple of weeks.
FYI... Here is a video from Shock Surplus that helped convince me. Enjoy. :)
sledboy
So I got the 5100s installed on the Bronco. It't a lot more difficult than installing new shocks in a Jeep Wrangler. :oops: Changing shocks in a coil-over is a pain!
But wow! It made a big difference and I am very happy with the outcome. They took all the harshness away. It is still firm but no longer harsh. I am now able to drive over rough terrain about twice as fast as I was able to with the stock Bilsteins. This is the ride I was expecting when I got the Bronco.
Just a few notes...
  • After watching the video that I linked to in my previous post, I was a little worried that the ride would be too soft. It's not! It is still firm but not jarring.
  • The stock Bilsteins were so harsh, we would air down our tires to 20 psi nearly every time we hit dirt just to take the edge off the bumps. To get an idea of how the 5100s improved the ride, they feel a little bit softer than when we would air down. This is a significant difference. Now when we air down, it feels even better. :D
  • On-road handling was not effected. It seems to drive and feel the same as before.
  • I was also a little worried that I was "down-grading" my shocks by installing the 5100s. But I believe the 5100s are better shocks than the stock yellow Bilsteins. The shock shaft is bigger and the finish is better on the 5100s. It is definately an upgrade and the resulting ride is better.
  • Best $500 I have spent on the Bronco so far!!!
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
But wow! It made a big difference and I am very happy with the outcome. They took all the harshness away. It is still firm but no longer harsh. I amnow able to drive over rough terrain about twice as fast as I was able to with the stock Bilsteins. This is the ride I was expecting when I got the Bronco.
Just a few notes...
  • The stock Bilsteins were so harsh, we would air down our tires to 20 psi nearly every time we hit dirt just to take the edge of the bumps. To get an idea of how the 5100s improved the ride, they feel a little bit better than when we would air down. This is a significant difference. Now when we air down, it feels even better. :D
Thanks for the update. I may have to try this. I have a 2-door non-squatch Badlands, and compared to my other vehicle (Jeep Grand Cherokee), the FAR harsher ride of the Bronco over bumps in the road is my only major complaint with it.
  • Like
Reactions: LCW
Obeh4ve
Zach
Home
TBA Bronco
I'm happy with my rear end (no jokes), but I've replaced trailing arms and track bar to get rid of all those hard rubber bushings, so maybe that helps. I certainly wouldn't call it a harsh ride on or off road. That's also with a lighter than normal load, as top and doors and rear seat are gone.
I guess I'm also used to Blazers on lifted leaf springs and my Tacoma on lifted leaf spring.
Who made the trailing arms? It's very unusual for someone to lower the durometer value of suspensions bushings. Aftermarket almost always goes higher. Usually rubber to urethane. Don't have our Bronco yet but know which vendor provides what options I'm making a list on how to dial in the suspension on the Bronco
kodiakisland
Arkansas
Honestly, there are too many companies producing rear trailing arms to keep up. Hopefully someone has tested the various models to get range of motions on all of them. I know there are some great Jeep videos doing that as some components have less ROM than factory.
I have Camburg as they were the one and only arms when I bought mine. I would most likely buy Rock Jock arms now.
Obeh4ve
Zach
Home
TBA Bronco
They did add a rear sway bar on some models for 22 but I haven't seen a definitive list of which ones get it. On uneven bumps that would increase the effective spring rate.
Bumps don't technically affect spring rate. Spring rate is set by the specs of the coil steel. For a linear spring the rate is the same across its duty length. Progressive rate springs do load up as compression increases. That's their "thing". Under fairly high differential loads across the axle a sway bar may make a difference in felt impacts. But if you're cruising along on a mild bumpy road like something with uneven or swollen expansion joints a sway bar will make no appreciable difference. On my old Mini I've changed the bar from full soft to full hard and felt almost no change. That was 125% stiffer than OEM to 275% stiffer. It definitely wanted to rotate more at 275%.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I like my Sasquatch Bilstein's and I don't think the rear is stiff at all! I do know they outperform many upgrade shocks at higher speeds, Shock Surplus has done a few videos on options for the Bronco...
Ibuprofen3293
Tom
Detroit
22MY Badlands
If anyone here wants to soften up their rear end by removing the sway bar, I’ll gladly it buy it from you.
Lowering the tire pressure from 39 to 35 gave me all the ride comfort I need. Just need to tame the brake dive a bit.
