Tire chains purchases begun
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
Just picked up the first pair of tire chains for 37” tires. Next set will be v-bars. Tires and wheels will be ordered soon. Probably should decide at some point FE or BL.... :)
Ford Bronco Tire chains purchases begun F27D8C40-5EAD-43CA-A22A-7E4F378305FA
Hey19
JJ
Bethlehem
Looks like you’ll be ready for Raton Pass next winter!
The Bronze
The Bronze
Kelly
Never know when you will need a bit more traction!
Ford Bronco Tire chains purchases begun 51F47A63-C86A-4DED-8FE7-F2F9E7D13A3D
JHawk
Ray
Heartland, USA
Fusion Sport
Since we have time on our hands.....
I have not had any experience with chains since high school in the '80s on a pinto no less.
I have thick skin so go ahead with the jokes. With the chains I could go on any unclear roads in my rural town with no issues (no offroading). So if you have time educate me on chains, cables, other options and the pros and cons. The best places to shop for them. and what is a V-bar. Thanks in advance for the info.
I am in KS but have family in CO and spend a lot of time there too. I hate how the shady spots on the passes ice up. Really wakes you up.
Blue Bronco
G
Earth
Boots
Man wtf are you planning on getting into that you already bought chains. I don't even run studs haha
I was in Big Bear, CA once and they had a mandatory chain up. Alternatively, I think if you had tires with that snowflake symbol you were exempt, but everyone else needed to put on chains. Think other areas have the same deal if conditions warrant it.
dgorsett
colorado
F250, Mustang, Explorer
Chains are going to be one of my first purchases if I Squatch. If I don't Squatch I already have a set or two that will work. I'm concerned about clearance to suspension components. From what I've read on 6g I think rears may be OK even Squatched but fronts may be out of the question (as they are on my son's Tacoma). If Squatched I may go to 285 or 275 width tires, so that might help.
Also, if I plan to chain the front that Squatch M210 will be much more reliable than the standard M190.
I never use chains on a 4x4 on road, even with chain law in snow tires and/or 4x4 will pass muster. But off road chains are invaluable, better than lockers, in deep snow and mud.
The Bronze
The Bronze
Kelly
I have chains for my other rigs and will be getting a set of v-bars for the rear. If need be (front suspension clearance issues) I will get some cables. They have some tight fitting cables these days. I haven’t ever run chains on the pavement either, but seem to chain up many times a year on the mountain trails, usually to recover someone who didn’t have chains and couldn’t self-recover.
LarryZiegler
Larry
To be specific, in Calf, there are 3 levels of chain control: 1) Chains required except for vehicles with snow tires (which includes all season/mud & snow tires & must carry chains) 2). Chains required on all vehicles except 4WD Vehicles with snow tires as in 1) and must carry chains. 3) Chains required on all vehicles. If #3 is in effect, you shouldn’t be on the road as conditions are extreme and dangerous. Lastly, I will wait for my Bronco to verify what type of chain is required based on fitment within the fender well
Blue Bronco
G
Earth
Boots
Good to know.
JHawk
Ray
Heartland, USA
Fusion Sport
Please share when you determine what will fit in front fender well
The Bronze
The Bronze
Kelly
Here are some pictures of the tire chains with an Icon 3" lift and my 37" tires, and Method 0-offset wheels. Plenty of clearance for the chains to the control arms now. A 1.25" spacer would work just as well if keeping the stock wheels or near-stock offset.
Ford Bronco Tire chains purchases begun IMG_3072
The chains will get pretty close at max compression. I am adding an inch of lift to remedy that soon.
Ford Bronco Tire chains purchases begun IMG_3073
Here are the rear:
Ford Bronco Tire chains purchases begun IMG_3071
Ford Bronco Tire chains purchases begun IMG_3070
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I know in my neck of the woods, you're required to have M&S or snowflake rated or carry chains.
I don't know why a vehicle, such as a Bronco, would ever need chains. It's very capable as it is.
  • Like
Reactions: Cat
dgorsett
colorado
I only use them off road, steep deep snow. The only way
