Thunderstorm Causing Dash Alerts?
HalfmuleFarmer
Thomas
2025 Badlands
Here’s an odd one. I searched to see if I could find anything here relevant but no luck. Parked outside yesterday afternoon for a dentist appointment, and while I was inside there was a big thunderstorm with some crazy lightning. Bronco was parked and shut off.
On the 5-minute drive home, the Bronco threw 4 or 5 different dashboard alerts, including a Hill Start Assist Warning, Pre-collision Assist Not Available, an ABS system fault, AdvanceTrac Service, and the Parking Brake “not fully functional.“ All telling me to schedule a service ASAP. (curiously all sort of brake-related?)
There’s been nothing going on with my driving or anything unusual that seems like it could have caused this. The truck is a bit dirty and dusty but I cleaned off all the bumper sensors. I disconnected the battery for 15 minutes, hoping a reset would clear the alerts, but no luck.
Reddit says:
“… Yes, thunderstorms can affect car electronics. During a thunderstorm, there can be a buildup of static electricity in the atmosphere, which can result in electrical surges. These surges can potentially damage the sensitive electronics in a vehicle, such as the engine control module, the infotainment system, and the navigation system.”
Any thoughts B6G geniuses? Could the thunderstorm have fried a sensor or two?
VirginiaHeritage
Frank
‘25 Bronco HE
While it seems plausible, I’ve never seen it happen.
More likely: it was aliens.
Edit: jokes aside, I’d be looking at wire harnesses for a rub-thru short. That and fuses. However, I’m not a B6G genius. I mostly tell questionable jokes.
VirginiaHeritage
Frank
‘25 Bronco HE
So you let someone stick metal tools into your mouth during a thunderstorm ?
Bro, your Bronco’s fault codes are the least of your worries.
My wife steadfastly refuses to shower during a thunderstorm. I don’t know if she’s paranoid or just smarter than I am.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I took a right at a stop sign late one night, hit a big ripple in the asphalt and everything lit up, including the e-disco being out. Told me to take it in for service ASAP. Was that way the rest of the way home (about 20 minutes).
Took it in for service; by then it was all gone (like 3-4 days later, I hadn't driven it until the 0.8 mile drive to the dealer). Took it in anyway and the service tech found a ball of tar stuck to the wheel speed sensor or something?
My guess is it's something like that.
HalfmuleFarmer
HalfmuleFarmer
Thomas
2025 Badlands
HalfmuleFarmer
HalfmuleFarmer
Thomas
2025 Badlands
Sounds like Mule has one too many mercury fillings in his head.
Most likey a coincidence and you're having a battery issue or maybe a wheel speed sensor issue?
Update: Checked the wheel speed sensors visually, seem fine. Drove around for 15 minutes and all the alerts cleared.
HalfmuleFarmer
HalfmuleFarmer
Thomas
2025 Badlands
Everyone here is a good source of laughs, as usual, but the situation leaves me wondering what could be the cause such a cascade of warnings to go away as mysteriously as they arrived. Likely no on the wheel sensors, seemed fine. Battery fine. Gremlins in the various sensor systems not so rare I guess. I’ll have Ford pull some codes when I go in for the harness recall (hopefully in Sept).
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I for a change was being completely serious. You can @ or pm Ducati or Flip. and see if he'll pull your VIN's codes if you don't want to wait.
Ford Bronco Thunderstorm Causing Dash Alerts? 1788045181045-so
