Throttle Response Controller... WOW!
Stu10
Stu10
Seth
Austin Texas
2022 Ford Bronco Outerbanks
Ha ha!
1. I'm digging your Porsche, the color and wheels.
2. Yeah, the pedal commander ain't gonna turn our moving blocks into track monsters.:)
And I don't think we're approaching it all that differently. As expected, with all the additional weight I threw on mine ( tire and wheels, front and rear bumpers, rock sliders, winch, light bars, subwoofer, etc), mine slowed down tremdendoulsy. I just wanted to try to recapture as much of that as possible, and the pedal commander and jb4 tune helped with that. I think if you were to lose some of the zip that you're currenltly accustomed to in your Bronco, you'd want it back.
For speed, I hit up the dragstrip in the ZL w/ 934 hp to the wheels. And even with that, I still started smiling when I took the Bronco for the first test drive after I put in pedal commander. To me, it was that much of a game changer.
I need to see more pictures of your bronco and that wrap! I have the 5" ADV fenders sitting in my garage and I am debating whether I paint match to Area51 or just do a satin black wrap!
Looks awesome! What are the specs of the wheels/tires and lift for the Bronco as well?
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
Installed my BMS Pedal tuner and man, it definitely made a difference. The lag in the pedal is gone. Normal mode now feels like sport mode, but the problem is the transmission is still lethargic. I think a Procal tune would wake it up, but since I just got a JB4 I think I’ll wait until custom tunes become available. Oh. and the JB4 with the pedal tuner is the real deal. It feels like a different vehicle.
Goneboy
Atlanta
Small Handful
Thx man. 👍 You're gonna love your adv fenders. They just give the Bronco a more muscular look along with more road presence.
I'm a huge fan of wrapping my cars. And if they're garage kept and don't get constant exposure to the elements, it'll last and look good for years. With my Bronco, I also added PPF over the wrap on the sides because I was worried about the tires throwing rocks.
Nitto ridge grapplers 38x13.5
Arkon Roosevelts 20x12 -51 Offset
Zone Offroad SAS 3 inch lift w/ upper control arms
Ford Bronco Throttle Response Controller... WOW! 20221109_175226
Ford Bronco Throttle Response Controller... WOW! 20221109_175251
Ford Bronco Throttle Response Controller... WOW! 20221108_134831
Ford Bronco Throttle Response Controller... WOW! 20221108_134841
Ford Bronco Throttle Response Controller... WOW! 20221108_134821
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Sorry if this has already been asked, but how does it compare to just using Sport mode?
The main reason I’m looking into a PC is because I hate the sport mode shift points and how long it hangs onto gears for day to day driving. Adding a pedal commander would give it the perkiness of sport mode while retaining the shift points and behavior of normal mode. For off-road I’d turn it off since I want smooth/laggy throttle
0ne
Nate
CO
Flex
This👆…I understand why people want the throttle gadget but Ford already engineered the GOAT modes appropriately in my opinion.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Did you read my full reply? Obviously it’s a matter of personal preference but Ford’s sport mode isn’t great
mpeugeot
Just curious but do you think Ford engineers the throttle lag and lower throttle signal inputs in all modes to save drivetrain parts like transmission, xfer case, driveshafts and axles?
If so, then they should have fired the bean counters responsible and put in beefier parts.
Nerfing the engine response is not the right answer. Suzuki did something similar on the SV1000s, they intentionally retarded timing in first gear to make the motorcycle less wheelie happy. So stupid, getting rid of the timing retard made the bike so much more responsive in 1st gear. Ford has essentially done the same thing here.
Now, I don't expect Ford to warranty intentional abuse, and nerfing the motor doesn't prevent someone from being abusive. Ford should have used the 10R80 and not the 10R60, at least in the advanced 4x4 transfer case Bronco. It's been suggested that the standard transfer case is weaker than the Advanced 4x4 transfer case. Also the M190, really should have never been an option. The M210 should have been the standard front axle in all Broncos, locking in the sasquatch/badlands and non-locking in the other Broncos. It would have been tremendously helpful from the standpoint of parts commonality.
Instead, Ford nerfs the engine.
mpeugeot
You should try Baja mode then lol. It hangs onto gears like a tick on a dog.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Difference is Baja isn’t intended for daily driving. One could argue sport isn’t either but it’s far more applicable to day-to-day road driving whereas Baja shouldn’t be used on pavement.
0ne
Nate
CO
Flex
Did you read my full reply? I prefaced my opinion and I’m agreeing with you bud, especially the part I quoted because no you do not want twitchy throttle off road, exactly the way Ford engineered it. I think Bronco sport mode is sufficient considering the platform and intended purpose.
mpeugeot
I can't imagine daily driving in Baja mode, but I have almost exclusively daily driven Sport mode and after 62k miles feel confident in stating that Sport mode is a daily driver friendly mode.
Ducati1098
There are Explorer ST’s running 10’s with a completely stock 10R60. There’s no reason for a 10R80. The 10R60 isn’t weak by any means. Not to mention they shift much smoother than 80’s.
woof
2022 BMW X5, 2023 Bronco
I don't post very often. In previous vehicles, I installed a catback, cold air and tune, which usually cost about $2500-$3000 with what I thought was a decent gain.
I have the 2.7 on the sasquatch with the higher gearing.
The Pedal Commander turned out to be real for me, I'm pretty shocked. No need for my standard mods with this thing as it out performed, provided much greater gains than my previous standards.
I like City +2 mode. I took the bronco out for a test with Sport today, it chirped the tires around the corner and was a bit more 'jerky' for me.
Switching between my cars was always an adjustment as the other one is just smooth pure power / fast. This has closed the gap and makes the transition easier.
My home's street / outlet is into a blind corner where some special people go 60+ mph. The bronco without the PC didn't feel as safe as it does now.
BadmansSAS
2024 Bronco WildTrak
Once people drive one with the PC on there, its usually eye opening. Its a gimmick for sure, but it really does get you in the power quicker and the perception of it is mind blowing.
I changed the pedal feels in my tunes for the coyotes without using a PC or anything plug in. People were mostly blown away how much faster a car feels when doing street driving with a turned up pedal. And I really had them turned up. Check out that pedal curve.
Ford Bronco Throttle Response Controller... WOW! 1712247629893-jy
bradcd
Brad
Indiana
Saab 9-3
I agree, it's the first performance mod you should do since everything remains fully stock. You're able to use the power you have available sooner.
