Thoughts on my ideas appearance
Area51BS
Ron
Badlands non SAS 4dr 2.3
Put this is general as it crosses over between wheel, tires and suspension. Not one or the other section.
22 Badlands non SAS on 33’s. 14k miles. Florida has no extreme off roading. I don’t care to wheel in mud. But do some trails/beach.
I want just a slightly different look. Once rear shocks are replaced I plan to sell the OEM and put on the 5100’s most likely.
Going for a 1inch lift since keeping 33’s for now. And new take offs are cheap when I need new ones. Although 35’s may happen if the itch hits. I would rather spend the money on rims with about 1in less +offset than non SAS rims than 35’s. Making tread edge even with fenders matching the 1 inch lift. Lift only would look odd on smaller tires in my opinion. Thoughts? Anyone do it?
BUCKIN6VA
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
My only thought is that a 1" lift on non-sas seems like a lot of effort for not a lot of results. Just my two cents.
Area51BS
Area51BS
Ron
I’m thinking any higher on 33’s would look strange. And the 1inch lift with 1 inch wider stance would look like something is different but not obvious.
PWillette
Parrie
Maine
1" less positive offset from non-squatch puts you pretty much at squatch offset...non-sqautch +55 minus 1" (25.4mm) = +29.6mm. Many have swapped over to the squatch wheels to acheive this or add a 1" spacer to your non-sqaucth wheels. Not a lot of other positive offset options available...+18 & +12 seem to be most common.
Zero Options
Connecticut
Is it a 2 or 4 door? If we are talking strictly looks, I think 33s are perfect on a 2 door but 4 doors look better on 35s.
ChrisB351
Shreveport, LA
33s (295/70r17) 17x9 -6 offset non sas suspension. Its a perfect setup for every day driving. I have pro comp coilovers waiting to go on and gonna need tires soon. At that poing Im going bigger.
Ford Bronco Thoughts on my ideas appearance Bronco6
Area51BS
Area51BS
Ron
I don’t want it to look like just another. Bronco. And not that I dislike Method wheels. Prob don’t want those either as they are too common.
Area51BS
Area51BS
Ron
4 door. The set up proposed would allow for 35’s of I decide to spring for them.
Area51BS
Area51BS
Ron
I do like silver rims. Looks good.
Area51BS
Area51BS
Ron
I’m also not keen on removing crash bars. No idea why Ford didn’t design the Bronco to maintain them with 35’s, which obviously they offer as standard.
