The Ultimate 37s/38s Tread
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
I get messages every week asking me questions like will it fit. I have 0 issues helping but I usually just send them to a certain post on my build.
My builds are at the bottom of my post.
Hoping this will save people the time of reading my build but I can still help them.
First off let's talk 37s, You have 11in, 12.5, 13.5 wide and not all 37s are really 37s. The KM3s that I used are really 36 1/4in @36psi and 36 1/2in at 50psi. Rim width will change width of tire also.
But some 37in tires are true 37s that will make a difference being I was as close as you can get to rubbing.
Now what did I do 37x12.5r17s KM3 (36 1/4in tire) on 17x8.5 +30 offset and 1/4in spacer.
This will be your tool for comparing (This will also tell you your poke difference if you put my numbers in then you can compare it will give you mm just convert to inches)
https://www.willtheyfit.com/index.p...ct2=80&wheel_size=17&wheel_width=8&offset2=55
Free up room with.
Zip-ties you will use them in the front and rear in different spots. (For more on that with pics you just have to read my build)
At about 7:25 in the video he goes over a part you can take off the bronco and free up some room.
Now I have the Badlands with Sasquatch So when it comes to lift use this to compare. (Thanks North7)
Ford Bronco The Ultimate 37s/38s Tread 1623923171610
Now I was maxed out with my 37in KM3s (36 1/4in tire) and full 37 will rub. Maybe a true 37x11r17 may work width is the problem with 37x12.5r17
One thing I will point out for the extreme guy that is jumping his Bronco I did rub jumping but very little. (Just in the front) Full 37s You will need a leveling kit for sure. ((I have now went jumping with my 1 3/8 front leveling kit and 1in rear leveling and no spacers had 0 rub, Same 37s )))
Ford Bronco The Ultimate 37s/38s Tread IMG_8879-2
True 37s (If you are a very little off road or don't mind rubbing at full lock above will be just fine)
Lets talk True 37in tires
You will need the JKS max tire kit to have 0 rubbing. (This will just free up a ton of room My 30+ offset works I can't promise but my guess would be you will be good all the way to 0 offset)
Lets talk 38s
You will need a minimum of 1 3/8s lift front and 1in rear.
With my 30+ offset no rub till off-roading then needed 1in spacers.
You will need to grind a little off the rear crash bar or just cut off.
No rub with the lift with the 37s jumping. Like above before.
OK, so 38s I knew they fit BUT the question was the spare. ADD bumper came with a 3rd brake light bracket. At first I needed a 1in spacer due to that 3rd light bracket hitting the tire. I cut part of it off and then didn't need a spacer its like a perfect fit. See pics
Ford Bronco The Ultimate 37s/38s Tread image6
Ford Bronco The Ultimate 37s/38s Tread image4
Ford Bronco The Ultimate 37s/38s Tread image5
Ford Bronco The Ultimate 37s/38s Tread image3
Ford Bronco The Ultimate 37s/38s Tread image2
Ford Bronco The Ultimate 37s/38s Tread image1-1
Ford Bronco The Ultimate 37s/38s Tread image0-2
All The time I had may post more later
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Great post. Another data point: I just fit 37x14.5x17 Swampers on Sasquatch wheels and no spacers. Tons of room.
Ford Bronco The Ultimate 37s/38s Tread PXL_20230211_225111637
Deleted User 5719102
Who's
On a Lake
22 2dr
Are you at full drooped in this picture? It has to be with the uca and CV angles.
Who's
On a Lake
22 2dr
Tricky Dick
Dick
PNW
refade1
Christian
Los Angeles
Camry
How are those shocks?
Tricky Dick
Dick
PNW
Well...miscalculated what groove to set them at so I have to tear it back apart. They felt nice around the block though.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
What wheel offset are you running? No rub at full lock?
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Holy shit that CV angle
Bikeric
Tulsa
2022 Badlands LUX on 37's
@Bradley Thornton I appreciate the fact that the JKS Max Clearance system is out there, but I'm CHEAP. Can a person simply cut off the rear bracket and cut down on the front bracket to still leave the important part of the factory body mount there??
KompressorV12
Portland, Oregon
Full droop
I'm still new to the IFS limits. But it looks like at that full droop even in 2wd you would tear your CV boot. Am I wrong?
Tricky Dick
Dick
PNW
I don't think it's beyond the factory droop so I'm assuming it will be fine. I've never pushed IFS hard before the Bronco either.
kodiakisland
Arkansas
Just playing around in the driveway and not full droop. 19K miles with no problem so far. You should be OK.
Ford Bronco The Ultimate 37s/38s Tread 61F6862B-F44E-4B5C-8CC3-1F8392C89815
