tapping into high beam wire
frkrican2004
freddy
New York
I am adding 4 ditch lights and wanted to know it i can tap in my high beams fuse or wire to have 2 ditch lights come on when my high beams come on plus still run a wire to Aux 5 to control when i want to flick to switch. The other 2 ditch lights i plan on tapping into the turn signals so they blink.
grayshadow
Charles
Humble, Texas
You can’t be serious. If they are off road lights it’s illegal to use them on the roadway.
Hopefully you will reconsider the ā€œblinkingā€ so we won’t go blind at night.
GToddC5
Todd
South Jersey
www.bronco6g.com
This is such a bad idea . . .
Ford Bronco tapping into high beam wire 1672096516966
RHeinz
Ric
Houston, TX
Wow! The responses are a bit harsh. However, if you live in a State that requires a safety inspection, I would hope this would NOT pass.
j_marinelli
Spring Branch, TX.
LOL I can see the inspector now when he ask to flip the high beams on šŸ˜‚
Ford Bronco tapping into high beam wire giphy
But to answer your question, not sure if it could work to be able to control lights with high beam and an Aux switch.
@4x4TruckLEDs.com might be able to shed light on the topic (pun intended) as he is well versed in off road lighting
frkrican2004
frkrican2004
freddy
New York
Yea forgot to mention I will be using the drls backlighting for my blinkers. Thanks for all the feedback unfortunately it was worthless🤣🤣🤣
vzqhsg
MI
F-150, Badlands
Yep...pretty bad responses. Your better off writing Dr. Laura!!
frkrican2004
frkrican2004
freddy
New York
Yup!!
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
Bet you weren’t expecting to get your ā€œass eat outā€ just for asking a question.
Sorry it happened.
There are quite a few on here that don’t consider before they post.
I don’t know the answer to your questions. My driving lights are on my #2 auxiliary switch. And yes I sometimes use them on empty roads.
Good luck with your project.
ā€˜21OBX
90Bronco19
2022 bronco outer banks
I have an Amber side and a white(bright side) to my ditch lights. I’ve often thought the same have the amber blink with the turn signals and also have the ability to just turn the amber in with a switch. . I just haven’t tracked down the wiring diagram and what (diode) maybe would be needed not to back feed the system when turned in by a switch. As far as hooking then to the brights I’d just put them on a switch. Because I’d be the one guy that a cop sees and get busted.
VIRUS
D
Wisconsin
Truck, car, feet
What the hell just happened?
