Tailgate Folding Table/Vault Installation
Last Ride Bronco
southern USA
Nissan pup
Have any of you personally installed the Swing gate folding table, the rear floor vault, or the front consule safe? I am wondering about the degree of difficulty. Thanks
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
No, but from what I hear, be careful drilling the holes, if you go too deep, you will hit the outer skin and dent it from the inside!
Should be easy...
cigartexan
Jack
Boerne, Texas
1964 F100 SS - 2012 F-350 SD - 2021 4D Bronco FE
Gotta use a lock stop collar on them drill bits.
Rednek
Jimmy
Northern Alberta
or just be carefull drilling,there is quite alot of distance between the inner and outer panels.
flip
Phil
IN
www.ruxerparts.com
Fords
Unless you are good with drill control get a collar stop for the 7/16". The bottom left hole is a double thick panel and will pull the bit through likely putting a huge dent in the sheet metal.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
I did a video of the tailgate table install,it wasn't to bad to do.
How’s the rattle a few weeks later? Probably rigged something more permanent than the tablecloth by now. Thanks for the video!
Rednek
Jimmy
Northern Alberta
it's actually nice to have the table cloth in there(saving space for camping trips)
kimmnen
Kim
Transit Connect & '22 Bronco Badlands
Would be nice if Ford punched the holes during the stamping process.
bigblueboing
Keith
Los Angeles.
Forester
Thank you for the video. However the shakiness made it unwatchable for me. I highly encourage any future youtubers to invest in a cheap gimble for their work.
dji osmo mobile 4.
please. And thank you.
MarkusBigBucks
Markus
Port Orchard Washington
2000 Ford Superduty 7.3 PSD, 2017 Ford Escape.
The tailgate table is easy install, the instructions sheet sucks. Do like another user did and put the rubber strips on the bottom in the bottom slots and on the top on the top slots. I added glow in the dark white vinyl behind my Bronco Cutout looks pretty cool I think.
Ford Bronco Tailgate Folding Table/Vault Installation B207D9C4-4388-48CB-BC8F-B6B2EF1831E9
