Tailgate Folding Table/Vault Installation
Thr33Thr33
Jesse
Fresno Ca
2021 Black Diamond
The tailgate table is easy install, the instructions sheet sucks. Do like another user did and put the rubber strips on the bottom in the bottom slots and on the top on the top slots. I added glow in the dark white vinyl behind my Bronco Cutout looks pretty cool I think.
How long would you say the total install took you?
MarkusBigBucks
Markus
Port Orchard Washington
2000 Ford Superduty 7.3 PSD, 2017 Ford Escape.
Half a hour. If you watch his video you will have a good understanding whats going on so things will be faster. Just make sure you dont over tighten the 4 bolts that go into the aluminum inserts. When I first opened my box and looked at it , I originally thought it was missing a bolt, its not. The bottom right mounting location will need to be held up a little bit before marking the location to drill as it will want to sag because thats the corner the bolt will be missing from. The bolt is not on that corner as you need to spread the frame to put the folding table part on the pivot pin or hinge however you want to look at that . Hope this helps..
BroncoBenster
Ben
Atlanta
'22 Bronco
Well....I stripped one screw and/or snapped the aluminum insert at the bottom right corner on panel because of the issue noted in the previous comment. I had to rig together with some zip ties. Thoughts on how I can extract that screw? part of the aluminum insert that snapped off is attached to screw, preventing me from pulling it out of the tailgate panel. Contemplating taking a bolt cutter to screw but worried about but end being a permanent resident and rattle in the tailgate.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Have any of you personally installed the Swing gate folding table, the rear floor vault, or the front consule safe? I am wondering about the degree of difficulty. Thanks
I installed the tailgate table. Not difficult. Watch install videos and put a bit stop on the drill for the proper depth.
Pdshepherd
Patrick
Gulf Breeze, FL
None. Wife's Kia is my part time wheels
That does look cool on the lettering for sure. Great idea.
