Sway bar quick disconnects
Manda13
Amanda
Corsicana Texas
Nissan Rogue
awall987
'23 2dr BaseSquatch
Hmm..with a $50 coupon code too. This is pretty much in the why the heck not price range.
NORCALGXP
Sacramento, California
2017 Raptor
NORCALGXP
2017 Raptor
Made in China
Company Name: PRIVATE LABEL MFG
Entity Type: CALIFORNIA STOCK CORPORATION - CA - GENERAL
File Number: 4827541
Filing State: California (CA)
Filing Status: Active
Filing Date: January 1, 2022
Company Age: 1 Year 4 Months
Registered Agent:
Map Icon spacer Stephanie Wu
280 Wattis Way
South San Francisco, CA 94080
Principal Address:
Map Icon spacer 280 Wattis Way
Mailing Address:
Products/Services: E-COMMERCE
FRANK WU
Chief Executive Officer
FRANK WU
Director
STEPHANIE WU
Chief Financial Officer
Frankie945
Frank
Louisville KY
Q50
IMO They’re more trouble than what they’re worth just hold out for another solution.
Bentpushrod
North Dakota
'16 Ram 2500, '18 F150
I’m running the AC Fab disconnects. I’m seriously thinking of just removing the sway bar entirely. Went to the Bronco Safari, disconnected the sway bar for Top of the World, and I haven’t reconnected it yet. Including the drive home, I’ve put on 1500 miles, and it handles just fine.
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I used to run no sways on my Xterra and it did fine, even with a shrockworks bumper and 9,500 lb winch on the front. With the amount that the front control arms are angled down, there is a lot of roll resistance built in.
No sways will be more “ponderous” in transition but it’s not the end of the world if you’re familiar with it and know what to expect.
kodiakisland
Arkansas
Yeah, the only time I have the sway bar installed is long interstate drives. Don't really need it then, but just like the safety factor on 900+ mile days when I start getting tired.
dgorsett
colorado
F250, Mustang, Explorer
So some folks totally remove, some use disconnects and may or may not reconnect. Does any company make a less stiff stabar? Beltech has an adjustable that lists one with 3 positions but instructions show only 2 positions, OEM and stiffer.
kodiakisland
Arkansas
Rockjock has one in development. Supposedly to be released this summer. I'm hoping they also have a rear bar, as I'm interested in only using a rear.
Cysquatch
Adam
Rancho Cordova, CA
2016 CTS, 1996 Silverado 4X4
Cysquatch
Adam
Rancho Cordova, CA
Run away sounds like a scam. I have ACFab.
Probably why they look identical to ACFABs at half the price ($152 when you preorder). The "release" price will be $295 but they are up for $195 plus another $50 off with code "Bronco".
fordbroncowildtrak2023
Phoenix, AZ
Silverado, Bronco
I have the AC Fabs installed but I also like to leave them disconnected for everyday driving. I notice a bit more roll but not crazy. I haven't had to do any sudden moves yet so maybe that's where it'll be a problem. I do like that the ride seems even more smooth without the bar connected.
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
Like others have said on here it's ponderous. I'd describe it as vague (maybe sketchy feeling when you first remove it) on initial input. But on sudden moves it loads up the suspension quickly and just locks into whatever you're asking it to do.
I'm not advocating anyone remove their Swaybar, you do you, but I was on the fence about it for months, finally did it and it's staying off.
2022 4 door BD Sas and most importantly WITH a factory rear swaybar.
