Sway Bar holding up front end
BadlandsCable
Phoenix, AZ
2017 F250
Ford Bronco Sway Bar holding up front end IMG_1809
On Badlands with Sasquatch Installed ICON EXP’s at 2” height. When sway bar is connected the lift is 5” and when disconnected it sits correctly at~2”. Anybody seen this issue with and how to adjust the sway bar?
billyum
William
Winder, GA
2024 Ford Bronco
I can’t say for sure about the EXP’s but I know for the CDEV coilovers you need the sway bar relocation plate. If I had to guess you’ll need it for your front end. Or you can be a total savage and just run with it disconnected all the time
Aonarch
Jack Hoff
MT
End links.
userdude
Denton, TX
2023 2dr Badsquatch
Enable lowrider mode by switching it on and off repeatedly...
BadlandsCable
Phoenix, AZ
2017 F250
Who did you get the relocation plate through? Does it also lower the skid plate for the sway bar
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
who did your install?
JBlanco
Julio
Charlotte NC
Don't come to SC!
Ford Bronco Sway Bar holding up front end 1712757901720-pj
JBlanco
Julio
Charlotte NC
billyum
William
Winder, GA
2024 Ford Bronco
No idea, a buddy of mine had to get the plate for the rear, plus they are completely different shocks. However you might be able to get away with just some quick disconnect links but I can’t say for sure
rtaylor
R
ID
19Raptor, 22Bronco
The Icon swaybar spacer doesn't affect the ride height. Just fixes clearance issues for full articulation with stage3+ coilovers.
The swaybar is supposed to rotate freely and shouldn't affect the ride height on level ground unless something is jammed up.
I assume that you drove it after jacking up the front end? It will sit very high until you drive it since the tires can grab the pavement laterally and won't settle immediately.
BadlandsCable
Phoenix, AZ
2017 F250
End links.
I have looked for some but they don’t seem to be mad
Yes, I have driven it multiple times and when disconnected it settles down and reconnected it comes back up. Has me perplexed because it doesn’t make sense.
akturbo
Seattle Eastside
I'm wondering if they managed to rotate the sway bar disconnect motor mount, I think it's possible if you force it. Need to see some pics of the sway bar setup. Also, what Hoss (1 vs 2) and groove are you on? I have Icon CDEVs and installed the drop brackets for the sway bar, even without the drop I wouldn't expect that to impact my ride height very much.
Ford Bronco Sway Bar holding up front end 1712761862934-cv
BadlandsCable
Phoenix, AZ
2017 F250
I’m on groove 5…so without sway bar connected it is spot on. I was also thinking about sway bar motor being rotated. The brackets are removed to allow lower arm removal.
