Swapping plastic bumper for Capable Bumper?
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
I can’t remember if the wired predominantly run on the top side or the bottom side of the bumper, but try multiple ways. They reach. Ford uses the same harness for the 2 bumpers.
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
I did not shave. I got the correct brackets. It was worth the $100 to not mess with shaving.
Here are the hooks in comparison to the other brackets.
is it possible just to leave the OBX hooks there and put the new bumper on?
Papa Smurf
Jax, FL
beepee24
Los Angeles
Nissan altima cp
Thanks, Sounds like I need the intercooler brackets w/o hooks and sensor mounting clips for complete install.
Hi. did you order these from Ford ?
Papa Smurf
Jax, FL
beepee24
Los Angeles
Nissan altima cp
Papa Smurf
Jax, FL
MB3Z6G079A and MB3Z6G079B
FoCoBronc
Colorado Springs
Thanks for your help. One last question, besides the tow hooks, is it possible to leave the plastic OBX skid plate in place. Someone thought if you leave it on you need to cut some of it off if you do not go the route of a new metal skid plate? Thanks.
Papa Smurf
Jax, FL
You will have to trim in order for it to fit.
Jeffola
Southeast Florida
2023 Bronco, 2023 Hyundai Santa-Fe, 2019 GT350
OK, just did this swap. The harness fits, but I found it necessary to Trim the keys for the Sensors located on the bezels. I removed a few key tabs, turned it 180, all works just fine. I added the KR Off Road dual light kit, so the fogs work , but I will finish the Off-Road lights tomorrow, Switch #2 and ground through a waterproof connector next to the front bumper connector.
I removed a bunch of wire holders from the harness, they dont work and add bulk. I tied the harness on each side of the opening for the Adaptive Cruise Radar Sensor. Wire tied it to the back intermediate brackets. Time consuming, but totally worth it.
Ford Bronco Swapping plastic bumper for Capable Bumper? IMG_8573
cactusbase
Alec
Bronco BaseSquatch
Does anyone have the part number for the metal plate that fits with the capable bumper?
Jeffola
Southeast Florida
Juiceisloose
JAY
22 Bronco BB
I switched out plastic for capable
Ford Bronco Swapping plastic bumper for Capable Bumper? 20230505_123524
Ford Bronco Swapping plastic bumper for Capable Bumper? 20230505_123556
Ford Bronco Swapping plastic bumper for Capable Bumper? 20230506_235217
on my big bend. You will need to grind off hooks or purchase the bracket and a new steel skid plate as well.
Jeffola
Southeast Florida
