Swapping plastic bumper for Capable Bumper?
Little Foot
Buffalo
Has anyone swapped their plastic bumper for a capable bumper? I’m wondering it it is as much of a pain as it for replacing the plastic bumper for a modular one.
Lak34ers
Troy
Seattle
I tried but I just didn't like the big gap that the bumper has between the grille and the bumper, plus you have to do some trimming to the plastic skid plate and you still have hooks showing... just didnt look right. I decided just to go aftermarket and have a metal skid plate that is meant for the bumper.
Little Foot
Little Foot
Buffalo
Cool. I was thinking about dropping the Modular Bumper, but was hoping to put on the Capable Bumper. Any pictures of your Bronco with the new bumper?
Lak34ers
Troy
Seattle
Have not decided on which aftermarket bumper I'm going with. I don't think I want a big bulky winch bumper that sticks way out. Not sure I would ever need a winch. Really contemplating the ARB Zenith since it is so well built and I can use my existing Diode Elite round lights. Maybe waiting to see what SEMA has to offer in New ideas.
Little Foot
Little Foot
Buffalo
I do think a lot of the bumpers designed seem to be too big and bulky.
Mr.Black
NS, Canada
Mustang, F150
Anyone have the part number for the capable bumper?
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
cyoungk
C
CA
Bronco Big Bend
Curious, what made you believe the modular bumper is a pain any moreso than the capable bumper?
switching basic to modular isn't that complicated at all as long as you order the parts. maybe you're talking about the tow hooks, but you can literally just cut those off or order the replacement brackets that normally come with modular bumpers. i'd imagine its just about the same as replacing it with the capable bumper.
the only complicated part is putting together a list of the appropriate parts and ordering them... assembling it is easy.
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
I just finished the plastic to capable swap in my OBX with parking sensors. Here is what I learned…
1. The wire harness is the same between the 2 bumpers, but they have different anchor points. Get out the zip ties!
2. The only difference between the sensors Is the angle that they connect. Swapped 2 sensors from the rear bumper to the front and everything fits.
3. Plan on rebuilding the bumper about 3 times. You’ll forgot something (D rings), or have to reroute wires, or some other reason.
4.The sensor brackets are not interchangeable. Either order them or make sure they come with the bumper.
5. Replace the flimsy plastic skid plate with the metal ones. Either buy the entire kit or find the front and engine plates.
6. If you don’t want to shave off your tow hooks, then order the brackets as if you had the Modular bumper. The parts numbers are out there.
7. It’s able to be done by yourself. It’s a great way to hide from the family.
Little Foot
Little Foot
Buffalo
Awesome. Thanks for the input. Did you shave off your tow hooks or did you go with the brackets?
MNBigfoot
MN
I guess I'm not understanding why anyone would not shave their tow hooks. What am I missing here?
Papa Smurf
Jax, FL
I did not shave. I got the correct brackets. It was worth the $100 to not mess with shaving.
Here are the hooks in comparison to the other brackets.
Ford Bronco Swapping plastic bumper for Capable Bumper? B39E77CB-2DB7-4C4F-9BCC-02CEE5F3B6F2
Lak34ers
Troy
Seattle
Just my opinion but get a used one and be ready for a install process if you really want a capable. Plus you will have the cpable bumper "gap". Buying all the parts and pieces and metal skid plate new is expensive. So much easier, cheaper, better built to go aftermarket and some even come with a matching skidplate like the JCR or DV8. Plus aftermarket has much better lighting options like light bar mounts etc... plus bull bar or grille guards. capabale just has fogs.
Function_7
James
'Berta
Just my Bronco
I’m working on the swap now, and I’m having a little trouble getting my wiring harness to reach all the way to the farthest sensor. Any tips or tricks?
