Suggestions for lighting on Raptor bumper?
Medicin3man
Frank
‘23 Braptor, ‘23 Telluride 4x, ‘10 FJ Cruiser TT
Good morning.
After much consideration, I decided against windshield mounted KC Pro6 lights. I would like to go with KC Pro6 lights on the bumper of my Raptor and KC ditch lights.
I only have experience with windshield mounted lights. How is the offroading with bumper only lights and does anyone have pics so I can see what yall have done?
Thank you.
Bschurr
NY
Good morning.
Thank you.
I had a single row 40” M&R light bar on my bumper (along with KC windshield set up) and removed it to install a winch. And then added ditch lights as well.
windshield mounted lights provide a better lighting experience but have a noise/wind trade off.
Ford Bronco Suggestions for lighting on Raptor bumper? 60710FBB-90D1-4460-8805-3A0C20B187D6
Ford Bronco Suggestions for lighting on Raptor bumper? IMG_1037
Medicin3man
Medicin3man
Frank
bigj
J
Massachusetts
24 Bronco Raptor
BD LP4 on the A pillar with SPV brackets are the way to go.
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
Bumper lights can affect cooling on the Braptor so I'd keep the form factor as small as possible.
I went with low profile roof lights as a result (Rigid midnight series) that have a harmonic isolator so no noise, along with Diode Dynamics ditch lights and upgraded Rigid driving lights on the stock, inboard location.
If you plan on getting a roof rack, take that into consideration as well. The low profile lights completely blend in and gives it a pretty clean look with my full rack installed. I also had planned to install a front brush guard (which I did yesterday) which also limited choices on the bumper.
Tye's setup admittedly looks bad ass. Curious if you get any spill on the windshield with the "side shooter" lights?
I also looked hard at the KC Pro6's Flex 4 for ditch lights as they included several lenses that are easy to swap out. Ended up with the Diode Dynamics SS3 Max which have similar light output and ability to swap lenses as well.
I don't have any great photos yet, really need to work on that.
Ford Bronco Suggestions for lighting on Raptor bumper? IMG_7768
Pre-ditch lights. It may be a single 40" row but they're incredibly bright. Road signs will blind you from the light reflecting off them, even at distance.
Ford Bronco Suggestions for lighting on Raptor bumper? Bronco Lights
With the full rack installed, it practically looks like it's just another rail since the Midnight Series has black PCB boards.
Ford Bronco Suggestions for lighting on Raptor bumper? IMG_7474
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
Ape Factory
Michel
Tye
Tye
San Francisco
I did not know those little additions existed! Got talked out of those particular lights due to alleged light spill on the windshield.
where u going to point them straight ahead or angle them to the sides as ditch lights?
Ape Factory
Michel
Ditch likely. Right now I have combo lenses but I need to get out to an open field and see what I'm missing coverage wise with my current setup. It's hard to find those in my neck of the woods without a substantial drive out of town.
Medicin3man
Medicin3man
Frank
These are great siggestions. Thank you everyone for participating.
I may have to look at those LP4's instead of KC. Question is, whats the light output on them, especially on the bumper. They look amber. Do they output the same as the KC Pro6?
Ape Factory
Michel
Better shot. Lights are absolutely blinding, even at high noon.
Ford Bronco Suggestions for lighting on Raptor bumper? _JF_0010
Ford Bronco Suggestions for lighting on Raptor bumper? Bronco1
vrtical
Doug AI
GSMNP, TN
Fords
My ProjectX work well with a winch. I run Diode dynamic SS3s pro level white with optional yellow covers ditch lights at whatever angle for fill.
Ford Bronco Suggestions for lighting on Raptor bumper? 1000004258
Medicin3man
Medicin3man
Frank
Baja Designs Lp4 on bumper and a pillar
What LP4 set up did you get? Driving combos for all 8 lights?
