Sudden Shutdown?
podad3
Len
NY
2022 Bronco
I have a 2022 Ford Bronco outer banks edition. For the past three days it has had problems. Initially, it would not start (completely non responsive) but then started perfectly a few minutes later. Later, after shutting it down it would not restart for several minutes. Today, on two separate occasions it completely shut down while at a red light and was completely unresponsive. I could not open windows or turn on flashers for several minutes, but after several minutes of being completely dead it started normally. Oddly, the only thing that seems to help is opening and closing the door several times. I called the local Ford dealership who told me they have no idea but if I drop it off they will be able to have someone look at it in a few weeks. I then called the national Ford customer service line and was told that they could not help until the problem was diagnosed.They suggested that I drive to a different dealer which I thought was a dumb idea since the car is unsafe to drive like this. I dropped it off at the local dealer but am now carless without a clue when I will get the car back. If anyone has any ideas on what might be wrong - or how to get Ford to do something please let me know.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Id start with double checking the battery connections as well as the Fuse Box Terminals in the engine bay.
I would inspect the AGM battery, load test it, and swap it out if there is anything of concern.
It might simply be a key fob issue, try using your alternate fob for a day or two.
If neither of those have an effect, its unfortunate to say but it'll most likely need some diag time at a dealer to pinpoint a harness/module issue
BlueBronco
DFW
What are you wanting Ford to do?
As pointed out, it sounds like something electrical. Did you perform any of the above checks before dropping it off?
Bschurr
NY
@Boreal good advice right there.
The issue certainly sounds like a battery/power issue so starting with the easy stuff is best…
podad3
Len
NY
2022 Bronco
Battery tests perfectly. And would be surprised if a harness or wiring issue as the car shuts down and then eventually starts while being parked/stopped. I’m thinking either a control module or software issue.
mike8675309
Minnesota
You say that, but that behavior sounds exactly like a power problem. A poor quality ground or power connection that, as it heats, builds resistance reducing battery voltage causing the vehicle to die. Then that cools off and passes electricity again, so you start it up until it heats again and kills the power.
The Bronco like all vehicles made in the last few years have specific power requirements that require a very small voltage range. If the battery voltage drops below that range, it will just completely shut everything down. Battery cable connections, positive and negative need to be very secure.
Boreal
Colby
MB
2022 Badlands 2DR
On my first Bronco, the starter died suddenly at 15,000kms. Perhaps yours is a tad kinder and is giving you a heads up that its on the way out the building.
It seems electrical for sure. Best of luck!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
Headsong
And here they are to (not) help!!
da_jokker
Jeep Wrangler JKUR
Sounds like loose connections. There are several known spots that need attention. Receive any checklist that helps out a lot.
Since you're losing everything, I would start with two areas...
1) Make sure all your fuses are fully seated. 90% of my fuses were not pressed in all the way when I picked up my Bronco.
2) there are three bolts that look like they hold your fuse box down...(which they do) But they also go into the wire hardness plugs that attach your fuse box to the rest of the electrical system. Those are always too loose from the factory. (They do go into plastic I believe so be careful and just snuck them up... Going back and checking them again after a few heat cycles)
3) all the ground, battery terminals, and fuse box terminals in that vicinity.
Beyond that, there was a known issue about some plug not being fully seated into a module behind the glove box somewhere. I think they even released a TSB on it.
podad3
Len
NY
2022 Bronco
Thanks. Ford got involved. Dealer looked at it. Said it was negative battery terminal had loose connection. I don’t know if that’s true because the car would stop and then start minutes later without any movement or jarring that would reconnect it. But I guess I’ll see.
Headsong
With pre-puckering, wondering.....horrible. I pray it works.
BigMeatsBronco
Allan
2021 FE 2 door
this is very common...after buying mine first stop for gas and it wouldn't start. dead, nothing...I opened the hood and flexed hard shaking all the battery terminals and whiz-bang it got juice again...
so after staring it, and pulling out of the gas stall, I pulled out the handy bronco tool pouch and used the 10 milli to tighten up the fools work... in fords defense I just suspected since mine sat on dirt Mountain for 6 months that they probably unhooked the battery to protect things from going dead, and then the underpaid goofball that hooked it back up it just shoved it on there and drove away.
Fasteddy
Ed
Oregon
2023 Bronco 2 Door, 1992 F150 4x4
Had a Focus behaved same way, poor ground connection on negative terminal to body ground stud, scraped paint off stud and worked perfect...
CitrusBronco
Everglades
Citrus county, FL
Everglades
Unfortunately you did what should be the correct action and straight to the dealer.
The correct action is check this forum first, dealer second only after this group can’t solve it.
The first advise you received was the correct solution.
A lot of people experienced this very issue and that’s why check the connections was given right away.
Hopefully you are good now and no future issues with this.
Might be a good idea for you to grab the new owner checklist off this site and check everything on the list. At least it helps you to learn more about your Bronco.
