Sub not turning on.
Would you still need that little doohickey if you’re upgrading the amp as well? Or is it one of those things to have now just as a precaution
If you are using an aftermarket amp (like a Kicker) - most of those can do line level detection and turn on when they see the radio signal come on, and they are pretty good about it. But it does depend on amp style/make/model.
I know with my Kenwood, I tried to use that signal, and didn't work at all. But switched over to line level detection and it works just fine - no issues. Forscan settings may have had something to do with that though - not sure how they affect the EN/CLIP signal.
If you are trying to use a Fusion amp or other Ford-OEM style amp, it seems to be hit or miss.
slow3v
2023 Bronco 4 Door
I am starting to think this is related to the SoC of the battery..
davedice
david dicesare
massachusetts
bronco
Hi there. I have a new 23 Big Bend SAS (2000 miles) mid package and at times it takes a while for the sub to kick in. Yes I actually have the full 7 speaker system non-B&O. I would assume that it only powers on when it senses signal from the main unit however I often have to turn it up past 17 or so and power it off and on many times then finally the bass kicks in from the sub. Has anyone else experienced this? I don't want a dealer trip just for that but not sure if it's a bad amp or just something loose. This speakers systems not the best but is total crap without the sub working.
Has anyone figured out the cause of this I have a 24 badlands doing the exact same thing and the dealer is useless it’s driving me nuts and for what the vehicle costs ford needs to have a solution
mack6319
mike
ohio
big bend
I wanted to bump this old thread to see if there’s been a fix. My ‘23 BB still does this. Frequently I have to turn the volume up past 20 to get the sub to turn on. It’s done this since day one.
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Bumping those post again… Sometimes my sub is on and sometimes it’s not. It never cuts out completely while driving when it is on however sometimes I turn the car on and the subwoofer is not on at all and nothing I do turns it on. I’ve tried resetting SYNC, turning volume up and down, and disconnecting/reconnecting my phone.
Only thing that gets the sub turned back on is a turning the car off completely, saying a prayer, then turning it back on. Any ideas?
23OBX2.7
AB Canada
2023 Bronco
It's a factory defect that an update or new apim will solve I had the issue and I think they tried both before it was fixed. It was also popping on turn on....
