Storing Hardtop (locating pins)
Chisox0508
Ryan
Atlanta, GA
How do you all store your hardtops? I was wondering if sitting it upright would be a problem because of the locating pins. I don’t want them to break so I was wondering if there was a more efficient way to store it, should I just take them off, or do you think it wouldn’t matter and they would be ok?
Ksjrb03
Tx
F250
Mine goes straight on the floor every time. Been sitting on garage floor for months since I put on Trektop. You could throw a couple pieces of 2x4 under it if your worried.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I’d throw a couple pieces of wood on the ground so it doesn’t sit on the pins. I’d also probably go overboard and try to grab an old wooden pallet from a business to use, so the weight is balanced out more and it’s off the ground. Usually you can find these pallets for free if you ask.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
I use one of these
Ford Bronco Storing Hardtop (locating pins) 1693698302935
'18 M2
2023 Warthog
The pins aren’t designed to hold the weight of the top and will break.
I bought four of these from Home Depot for $1.60 while I wait for my TopLift.
Ford Bronco Storing Hardtop (locating pins) IMG_0611
entomophile
Greg
2023 Bronco
I took mine off and store them in the tool pouch. I keep my roof on a wire ceiling shelf and it would get stuck with the pins on.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Any suggestions on how to remove them? I know they don’t screw out, so imagine you have to pop them out. Take a rubber mallet to them?
entomophile
Greg
2023 Bronco
NO! The bolts screw into the pins. Just hold the pins with some pliers and screw the bolts out.
Fly
MA
Subaru Outback
Is it much more difficult to get the hardtop back on without the locating pins?
entomophile
Greg
2023 Bronco
I haven't put it back on yet, but my plan was to put the pins back on first.
HCGxKaLiBeR
CT
2025 BMW X2 M35i
Ford Bronco Storing Hardtop (locating pins) 1694098039686
Ford Bronco Storing Hardtop (locating pins) 1694098056399
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I haven't done it yet, but I'm planning on lifting my hardtop off with straps, then just lifting it higher and letting it hang.
amazingjason
Jason
CA
1987 Samurai, 1966 442
Does this lift fold up when not in use? Is it specifically for two door Broncos or is it for Jeeps but works for Broncos? How does it get around the rear roll bar? Do you have a link to their website?
Jason
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
Mine stays on the Toplift Pro - always.
Ford Bronco Storing Hardtop (locating pins) 1694099829276
(photo cred: Topliftpros.com)
