B22-2023
Houston
we see speeds on the mini dish of between 100 and 160 mbps while in motion. Works great and consistent. Ive had it in my bronco for months now and love it.
A Blue Ridge attic just arrived, I’ll strap in the Mini next trip and see how it goes.
MungTM
Troy
Iowa
2023 Badlands
Check out this cool new Starlink mounting kit for the Bronco and Bronco Raptor. This is one that has been in the works for several months now. Been testing on the road with great success.
Mounts on the inside in the back section and bolts to the roll cage existing bolts. uses the Gen 3 Star Link system. I have been using the factory installed 110 AC inverter with the stock Star Link power supply and router and getting great connection speed. Fits right up tight to the roof. you cant even see it in the rearview mirror. You can also use a 12V power supply and plug into the 12v cigarette adapter in the back of the Bronco. Check it out. Super clean installation.
The mount has a quick release feature to remove the dish quickly and you can interchange mounts with a fixed mount you would use on a boat or RV and also a suction cup mount that you can put on the roof of a truck (maybe an F150 Raptor). Quick and easy to swap over with no tools.
Here is a little video clip of it in the Bronco Raptor.
https://www.facebook.com/reel/996372635195728
https://www.highspeedmounts.com/
Do you make anything that would fit a 2 Door?
PayHeedKU
Kansas
2025 CRV, 2000 Dodge Dakota, 2025 Bandlands (ordered)
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
Curious how this went. Seems to be a low cost method, but idk if it's secure enough..
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
Making monthly payments to “that guy” feels like a good way to hasten the descent toward a necessity for off-grid comms. But in that scenario, he’s the last person I’d want to have knowing where I’m at…
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
Ford Bronco Starlink Mount Kit for Bronco 1745072968940
I'm thinking of this orientation instead of side to side. It is tighter to the roof this way. (The tripod is just being used to hold it up there for pic, not the way I plan to mount it.)
mallaki
Peter
Cary NC
2025 Ford Bronco Raptor
I am getting similar speeds in the Bronco Raptor as I get with my roof mount on my F150 Raptor. so to be straight I can get up to about 280 MBS in most cases and it will fluxuate as you drive some. But normally at least 100 MBS and most of the time north of 200. sometimes you will see 300 MBS plus and I think that's just when you have perfect conditions.
Can you confirm whether the speed is 280–300 MB/s (megabytes per second) or 280–300 Mb/s (megabits per second)?
Typically, speed is measured in Mb/s (megabits per second), not MB/s, and Mb/s is eight times slower than MB/s.
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
Mbps
