Squared fender flare options for Bronco?
CoolContractor
Fred
I haven't taken the rear flares off yet so no pic, sorry, but it's going to look pretty much the same.
Are the rear doors the same as the Badlands or are they squared off as well?
Lowcountry Bronco
William
South Carolina Lowcountry
I'm a 2 door not 4 but all the Heritage's and Everglades fender flares are squared off, front and rear. Something cool the 4 doors don't get is the little slash aft of the rear wheel opening which is a nod to the EBs and is only on the 2 door Heritage's!
Ford Bronco Squared fender flare options for Bronco? PXL_20231005_134014509
gerby151
Randy
Clayton, NC
'22Bronco Badlands (Honcho) '09 Harley Davidson
BlueBronco
DFW
Can confirm that the rear doors are the same. And if you look at an HE the rear flare doesn't flatten out until well past the door. However, if you are thinking that you can interchange the flares, well, I just tried it and can also confirm that will not work.
Also of note, I discovered that the rear quarter trim piece under the brake light (the piece with the little Squatch sticker) is different on the HE's. The forward flat edge that touches the flare is 4" long on an HE and 4.5" long on a BL. This is on a moar door.
CoolContractor
Fred
I was just wondering if the 4 Heritage fenders with Heritage plastics would fit the Badlands. Somewhere, someone may have done it already.
BAUS67
redneck
Central PA
Well, the Bronco was designed with a modular platform. 😁
Ford Bronco Squared fender flare options for Bronco? dims
BlueBronco
DFW
I am about 98% sure they would be a direct swap. Besides the rear trim piece I mentioned, everything looks identical. Conclusion drawn from comparing them in person side by side.
STX Bronco
South Texas
F150 SuperCrew 22 Badlands
This looks great! I wish they were the same width as the Sasquatch flares to keep down the slinging crap everywhere. Your’s is one of my favorites setups.
GI_Jo_Nathan
Jonathan
Its been looked into in other threads. I think the conclusion was that it's too expensive to make sense.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I’m also running the KBD’s. Their prep and tape aren’t great, still pull up in spots after taking extreme care for proper cleaning/prep during install. They fade pretty easy, but still shine up decent with some quality dressing. I’ll probably have them painted at some point. Regardless, I love the look and get a lot of compliments.
Ford Bronco Squared fender flare options for Bronco? IMG_6931
Ford Bronco Squared fender flare options for Bronco? IMG_6982
Ford Bronco Squared fender flare options for Bronco? IMG_6826
Ford Bronco Squared fender flare options for Bronco? IMG_6823
Chritaka
DFW, Texas
Note those are 37x12.5 on 17x9 0 offset.
Below are some pics of the poke with the stock WT SAS wheels/tires.
Ford Bronco Squared fender flare options for Bronco? IMG_5447
Ford Bronco Squared fender flare options for Bronco? IMG_5446
Ford Bronco Squared fender flare options for Bronco? IMG_5450
Ford Bronco Squared fender flare options for Bronco? IMG_5449
HammerNQuill
Ben
Brooklyn, NY
2012 Nissan NV 2500, 2023 RAM ProMaster 3500
The square fender and the lower stripe is the look I've been after! Did you trim the stripe, or did you find one pre-cut? Do you have a link?
Ford Bronco Squared fender flare options for Bronco? 20230815_152406
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
Search KBD and Bestop for square flare options. No one's sure yet if you can transfer over the fenders and flares from an HE or EG yet.
They should swap over, but i wouldn't put anything past ford at this point given the number of option and trim-specific parts there already are.
