Speed limit reader
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
On my drive earlier today, I paid attention and it changed many times when turning onto a new road without a speed limit sign in sight. Therefore it has to be running off GPS...
My '17 Mazda CX-5 used both GPS and the camera, and I would guess that most vehicles do it that way. The Mazda also had a HUD and it would display stop signs and such that it saw as you approached. That car was the best bang for the buck I ever owned ;)
userdude
Jared
Denton, TX
2023 2dr Badsquatch
TBH, why should I believe you other than one of the actual real-life, shook hands, Ford engineers who built it?
Just because someone engineered it doesn't mean it got used (I know this from experience). So both could be right in a sense. For me, I would assume some map data would need to be used, since someone turns onto roads all the time without a sign anywhere to be seen. Ford could've disabled the cameras because of (fill-in-the-blank reason) and still been able to show it from the GPS/map data.
Aman
Aman
Northern NJ
Instead of acting like a jerk, why don't you go out and try it for yourself?
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Wasn't trying to be a jerk, but I guess it did sound like that. Apologies. I was just asking for clarification on what led you to believe that there was not a camera as a data input.
I suppose I could follow behind someone in a truck with various Speed limit signs, and have him/her hold them up, to see if anything changes.
Aman
Aman
Northern NJ
All good.
While your idea is an interesting one, just find a road that doesn't have posted signs and see what is shows in your Bronco.
I have a place on my commute that is devoid of speed limit signs, but the limit changes from 55 -> 40 -> 50 and the Bronco automatically changes to reflect this. The cops set up speed traps in that section all the time. :mad:
Bluedoggie
Bear, DE
23 Bronco Big Bend, 22 Volvo xc60
Omg, I think mine does the same thing. Your speaking of the Google maps that comes with the vehicle? I just never put two and two together to observe this. It reads 30 even when a 50 sign is in view.
My 2022 volvo. Had a similar problem but was corrected with an update.
I'm driving a my23 big bend, mid package 4.27 rear locking. I will follow this thread. Thanks
timhood
Tim
Several
When driving your vehicle the car reads the speed limit signs and posts it on your screen so you know what it is wherever you are.My previous bronco did it and so does my2021 f150
Edit: I and 27 other people before me said the same thing. 😁
I thought it was just using data from the nav system that included speed limit information. I thought for sure I remembered a time when I was on a road where the speed limit had been changed but the screen was still showing the old limit (meaning a road where it had previously been posted 45, but was now posted 40, for example).
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
Just went on an hour drive - mix of backgrounds and smaller highways - 25 to 55 mph and I would say the on dash speed limit display was accurate about 25% of the time. Sometimes too high, sometimes too low.
Wherever the data is coming from, it is extremely inaccurate and unreliable. Ford needs to give us the ability to remove the Speed Limit from the dashboard display.
BigMeatsBronco
Allan
2021 FE 2 door
I believe I've seen a forscan change that affects this exact thing. it gives you a choice of GPS data or Camera data, and even a "blend" of the both. ( one is likely default if the other sends no data)
RiotSquirrel
Florida (The pines part, not the palms part)
Triumph Bobber, Honda Civic
y'all... y'all have speed limit signs that come up on your dash?
is this a trim package specific thing because i definitely do not have that (it does show up on the map if i'm using navigation, but never on my dash area)
Ksjrb03
Tx
F250
Yes this can be set in Forscan! The Bronco comes from the factory set to GPS only. There is no debate here it is 100% fact. But you can use Forscan to set speed limit recognition to “fusion” and it will use camera as well. Like most other Fords.
mbdlds
It's reliant on having the built in navigation. My 23 had navigation removed because of a chip shortage, so no speed limit sign reading for me.
BigMeatsBronco
Allan
2021 FE 2 door
interesting, so which module is missing?
RiotSquirrel
ahhh, that makes sense, thanks! I only have the standard package, so no built-in navigation for me either (which seems a little unnecessary in the era of Waze and Google Maps anyway, honestly)
