Something doesn't seem right......
Jazer
Jessica
2.7 OBX
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
FYI. You don’t have to turn the brake off. Just apply a little throttle. Automatically disengages. I prefer the Maverick location on the console. You don’t have to look for it. Maverick also applied it automatically if on enough of a grade. Not sure if the Bronco does.
After some informal (non-Scientific) testing, it seems that the three times I have gotten the brake warning light (2.3 7m) I did not disengage the brake with the switch, I applied a little throttle like you said and it automatically disengaged. I have made it a point since to disengage the brake with the switch and I have not had the warning since. Coincidence? Maybe, but from now on I will push the switch. We have a Maverick as well and I too like the switch in the console. The Bronco also has hill-hold, very handy where we live.
AZ_Liberty
2007 Expedition
MIne was built 9/13/22 and it hinges at the top.
Mine looks identical to yours, Base, HPR, 7MT.
I erred earlier, mine was actually built in August. (I received it in Oct)
Never got a baby pic either.
hinges at the top.
AZ_Liberty
2007 Expedition
I turned that off before I left the dealership lot.
30 years of driving stick shifts, I don't need one acting goofy and putting on a brake when my foot isn't on the brake pedal.
Snowdogyyz
23 Ford Bronco Wildtrak
Definitely different between my March 22 built badlands and my 23 Wildtrak. I kept reaching down for it and thought they left it off! Then noticed it was flipped.
  • Like
Reactions: FRM
Laminar
Iowa
Cougar
You know what wouldn't break? An actual mechanical handbrake. You know what wouldn't break if it just had to be electric? A simple rocker switch.
Have you ever had an old truck where you can't use the mechanical e-brake because you know it won't release due to all of the rust built up on the cables?
Even the recent F-150s used a lever between the brake cable and shoes that would often freeze up and lock the ebrake on.
Ford Bronco Something doesn't seem right...... 1671816262474
My mechanical ebrake footpedal went out of adjustment to the point that I had to physically lift the pedal up to get it to register that the brake was released. I finally had to go in an reset the spring, cable, and pawl positions so it would behave properly.
Lots to go wrong in a mechanical system at every step.
RoLyMa27
Rodney
SloKart, TX
I just like not having to heel and toe it or partially release the clutch to hold without rolling back.
mpeugeot
This has got to be the stupidest design for an emergency/parking brake that I have seen to date. Can you imagine trying to use this in a situation where you needed an emergency brake at highway speeds while trying to control the vehicle?
Someone needs to be flogged over the positioning and ergonomics of that alone.
I still love my Bronco, but this was a huge mistake.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Old trucks in the rust belt have lots of problems. Electric e-brakes are going to lock up under those conditions too.
I have very few gripes about the Bronco, but I agree this could have been done better. But I'll live with it.
Laminar
Iowa
Cougar
Yeah I never said they wouldn't. But historically, mechanical e-brakes are extremely prone to fault and failure, unlike what you said.
Tricky Dick
Dick
PNW
Yeah I never said they wouldn't. But historically, mechanical e-brakes are extremely prone to neglect.
Fixed it for you. A little maintenance goes a long way.
Ducati1098
No, because it was clearly never designed to be used for this. It’s a parking brake.
JerryC
Memphis
2022 Bronco
In the vehicles with handle style, pull up e-brake i would put on the brake and the wife could not release it.
Over the years her hand strength got less and less to the point she had to retire. She loves the electric e-brake.
My e-brake pivots at the top. April of '22 build.
Dzrt1st
Roy, WA
BadSquatch, Toyota Tundra, RX7
Actually it was designed for emergency braking also per page 208 of the owners manual.
