Something doesn't seem right......
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
I did notice that from 2021 model year to the 2022 and 2023 the flipped the switch upside down. On my 2021 its flipped and you pull it rather that push it down on the 22 and 23. Seems really odd to me as well.
Mine is a May 2022 build and the switch is pulled up to set the brake. So either this is an oops or they changed mid year.
Umichigan1
2022 2-Door Bronco
I didn't have the patience to read through this entire post but here's what I think. The trim was designed for a mechanical parking brake lever, not an electronic switch. Therefore the trim has unnecessary clearance. Probably done late before production release and not worth the expense of redesign just to make it look prettier.
Mortonm
Canada
2022 Ford Bronco Black Diamond
My October 22 build pivots at the top.
I've only used it three times (bank drive up ATM)
Pull on, push off is weird enough.
Weird my Oct 19 2022 blend date pivots at the bottom
Cut off must be in there somewhere. The graphic above said after 9/16 but must have had a bunch left.
iBrad81
Brad
Cleveland
2024 Ford Ranger Raptor
Thought I was crazy first time I reached for it 10/22 build
Ford Bronco Something doesn't seem right...... 67734F53-AB8B-4F05-B9FB-702FDB64CD8A
  • Like
Reactions: FRM
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Is it a difference between manuals and autos?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
When I went to NV Off-Roadeo, they said you should set the parking brake all the time to prevent wear and tear on the gears. Any truth to this? And they were real specific on how to do it……while still in drive, foot on brake, set parking brake, shift to neutral, foot off brake, set to park.
They also said the logic on the push/pull of the parking brake is this: pull up on it just like you would an old fashioned mechanical parking brake. And push it down to release it, also just like an old fashioned mechanical parking brake. I think this explanation really helps with the logic of what to do.
Clemson Tiger
Wes
Georgia
2019 Ram 1500
I got a 7mt with a Sept 28 2022 blend date and it hinges at the bottom. It’s the exact opposite of my Ram truck so I am always pushing when I should pull and pulling when I should push. 🤔
  • Like
Reactions: FRM
Phil
Phil
2022 Tesla Model 3 LR
dead pedal looks different also unless it is different across trims?
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Being electric, it seems like it would be better for everyone to put the switch in the shifter and have it auto engage when the car gets put in park.
What’s this “park” thing to which you refer?
Cubertious
2022 Black Diamond Bronco
My 2022 that was built in March has it the old way with the pivot on top. This looks weird lol.
Mine is 22 as well (delivered jan 20) and also pivots from top
FRM
FRM
Russ
IDAHO
1978 Bronco, 22 Bronco Base , 19 Ranger
Mine was built Oct 22.
Ducati1098
That's very possible.
If someone wants to send me a VIN for a very late build 22 with auto and one with manual I could look up the part numbers for them.
etmccaus86
Evan
Motor City
'22 BaseSquatch
It's to relive stress on the parking pawl, not a gear per se...also prevents any bit of roll you might encounter.
vrtical
Doug AI
GSMNP, TN
Fords
Ford is dumb, electric brake, manual switch.
