Solution for popping/rattling MIC top!
Jabberwock
Jabberwock
Craig
Georgia
2021 Big Bend Sasquatch
If my roof begins to make this noise, I'll just plastidip the bracket. Or find an oval rubber grommet.
Might work. Let us know if you have any success.
The grommet wouldn’t need to be oval, a round one of the correct size would contour to the oval shape if the rubber is pliable enough. Only tricky part might be finding a grommet of the proper diameter that will also work with the thickness of the steel bracket.
I’ve yet to determine if the noise is caused by lateral movement of the rounded pin colliding with the sides of the hole in the bracket, or vertical movement of the rounded pin.
I’m all for a more elegant solution if someone can come up with one.
level3looper
New York
I took this vid yesterday. Is this the sound everyone is hearing? It ruins an otherwise quiet lovely drive. I'll be getting some foam today.
Jabberwock
Jabberwock
Craig
Georgia
Yes, sounds like it to me. Yours is even noisier than mine was but I found the level of noise was directly related to ambient temperature, obviously with colder temperatures things shrink and it rattles a lot more. Being in NY vs GA I’m not surprised yours is worse than mine. Hopefully the foam works for you and you can enjoy your time off road even more. Report back and let us know if it works for you. Good luck!
ProdigyJKU
2012 Wrangler
Had this happen on my 4dr 2.0 MIC once temperature dropped around freezing. I simply wiped a little spray silicone on the alignment pin and haven't had a issue since.
Had the same thing happen on my 2012 Wrangler hardtop as well.
87gpe
Phillip
Charlotte
Tahoe, Supra
My 2.0 MIC is ungodly annoying over the passenger side. I couldn't take it on one drive and had my wife just flip the latch over her head and it's mostly gone away. I haven't taken the time to work on figuring out what - but it was also tied to ambient weather, as it got cold, that thing got obnoxious.
LABRONCO58
Luc95rib!
I slid an even thinner piece of foam under mine and it seems to have done the trick. The foam is thin enough where it fits snugly around the pin thru the hole without puncturing the foam. Thanks for the post.
Jabberwock
Jabberwock
Craig
Georgia
Great to hear it worked and happy to help.
Bdisco
Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
The clicking / popping will drive you nuts. Washboard roads sometimes make me want to off road mine into a tree.
Will try some self adhesive felt furniture glides around the pins and tighten up on the latches.
level3looper
New York
Another thank you for your post pointing me to try the foam bits. I have had the foam in place for a few days now. The crackling noise is completely gone. As @LABRONCO58 did, I also used a thinner piece of foam that stayed with the pins when pushing the pin with foam through the hole.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Any evidence so far that the foam could affect getting a good seal and cause a leak?
level3looper
New York
I bought a rainbow pack of 2mm thick craft foam. For $5, I have enough for a lifetime for this task. Other than filling the pin hole, it squishes down to nothing. I'm sure it wont have an impact on the seal, though I'll comment again if I see anything.
I used the purple foam to make it easier to see what the foam is doing.
Ford Bronco Solution for popping/rattling MIC top! 20211201_160237
Ford Bronco Solution for popping/rattling MIC top! 20211201_160244
Jabberwock
Jabberwock
Craig
Georgia
Great to hear it’s worked for you as well. Happy to have helped.
Jabberwock
Jabberwock
Craig
Georgia
Great idea with the contrasting foam color to show others how this works.
Jabberwock
Jabberwock
Craig
Georgia
I’ve had zero leaks so far even with the heavy rain we get in Georgia. I would imagine as long as you aren’t using too thick a piece of foam it shouldn’t be a problem.
navi
Navi
CA
73 Bronco
I’ve been stocking up on grease and zip ties for these bronco fixes. My girlfriend kinda gave me a concerned look. :ROFLMAO:
