Solution for popping/rattling MIC top!
Ksjrb03
Tx
F250
As you can see by this thread a variety of materials will fix this horrible issue. I used plastic wrapper out of the trash can at a gas station during a road trip. 500 miles later not a single pop.
Ford Bronco Solution for popping/rattling MIC top! 7B96BB65-8E26-4227-9B45-674BD3AB9BB2
Ford Bronco Solution for popping/rattling MIC top! 744E81DE-898B-4C19-ADC6-B4F1544B5BA2
Jabberwock
Jabberwock
Craig
Georgia
2021 Big Bend Sasquatch
Mine started last week around 2k miles. I put a square of clear 3m wrap that I used on the sills over and inside the pin holes. Seems to have solved it for now.
Good to know a thinner and more permanent material is a possible solution s well. I have a bunch of clear PPF so I’m going to try that as well. It would be nice not to have to keep track of the foam every time I take the panels off.
Jabberwock
Jabberwock
Craig
Georgia
Improvise, adapt, and overcome. I love it!
Rlack75
Ron
Marietta GA
I'm wondering if using the rubber vacuum caps used on old-time carburetors would work too. They come in large enough diameters to cover the pin and would fit on tightly so you wouldn't need to deal with repositioning things every time you remove and reinstall the top. These are pretty inexpensive and can be purchased at most auto parts stores.
**Update: The vacuum plugs are too thick to allow the pin to fit into the bracket. So, I found another solution that is working so far. I wrapped the pins with electrical tape. Then I put a piece over the hole in the bracket and poked a hole through the tape where the hole is. When you push the pin through the hole in the bracket, the tape covering the bracket pushes into the hole and insulates. So far, so good.
Check these caps out.
https://www.bronco6g.com/forum/threads/mic-2-0-roof-popping.29343/post-1011088
Belem
Jay
Seattle, WA
2019 Mazda MX-5/2021 Ford Bronco First Edition
I had a nasty rattle and ended up putting some foam in the pins like the OP. Took the Bronco to work this morning and the rattle was still there...
...until I realized that the the passenger seat belt was twisted 45 degrees and was knocking on the b-pillar.
Ford Bronco Solution for popping/rattling MIC top! picard-face-palm
Tkekich
Terry
SE Michigan
2018 F150
Mine was built end of october and delivered end of november, so I'm assuming it has what they claim is "MIC 2.0" it has definitely has this rattle/pop right over the driver's head. I'm going to try this foam solution.
my mic 2.0 was also delivered in November with the rattle/pop above my left ear. I did the foam trick on both sides, problem solved! Now I'm getting this stupid rattle / pop from somewhere in interior rear cargo area.
EveryDayBronco
Motorcycle
I wonder if polythylene tape would do the same. It's 5 mils thick and made for friction and noise reduction.
APT, UHMW (Ultra-high Molecular Weight) Polyethylene Tape, Resists Abrasion, Impact, for Surface Protection and Friction and Noise Reduction for Lining Sliding Surfaces. (1" x 5Yds, 5 Mil UHMW) - - Amazon.com
Happy
Jerry
Missouri
CJ5, Wagoneer
Wanting to cover both the flat surface and the inside of the guide pin hole, we used self stick closed cell weather strip. It squeezed almost flat and is fairly stretchy. It squishes down into the pin hole.
Also used this underneath the black factory rubber on the front and rear corners. The black corner rubber is factory molded to move and squash up some under pressure. The weather strip adds just a little more pressure to this and hopefully will stop some wind noise. It flattens out so much that it may not do any good.
Ford Bronco Solution for popping/rattling MIC top! IMG_1050
Ford Bronco Solution for popping/rattling MIC top! IMG_1052
BLMike
N. California
Jeep Ultimate Wrangler and two other normal cars
Flocking tape I had laying around worked. The silicon spray did not work.
edit…to add I only did the two holes above the driver and passenger heads. That appears to be the place the popping comes from. Other holes have nothing.
Ford Bronco Solution for popping/rattling MIC top! 369B1C7F-60AA-4403-9188-7C52ED9B657C
Jabberwock
Jabberwock
Craig
Georgia
Great adaptation of the foam idea. I need to do something like this so I don't have to keep track of the foam scraps I've been using. It's good to know a much thinner material is effective. I haven't heard any noise coming from the rear panel or anywhere else on the top.
BLMike
N. California
Now that my front popping has stopped, I have heard something from the back. However, I haven't dug into yet. Sounds like it is coming from the way back. Vehicle is being wrapped this week and the OEM protection on the lip where the rear top sits will get new PPF. Waiting to see if that helps. I am almost tempted to ask him to replace my flocking tape with PPF scraps.
Broncolli
MD
'21 Back Diamond 4 door MIC
I used a small piece of a bicycle inner tube, laid it over the hole, and put the panel back in place. It has been a few months already, and I forgot I ever had the problem.
LIKEABOSS
Baltimore, MD
2024 Bronco Raptor, 2023 Z06, 2020 GT500
Just curious did anyone every report this to the dealer or just fix it themselves? We’ll never get a permanent fix from Ford unless people report it through official channels.
Delight
Delight
Cincinnati
Sequoia
Just put a dap of some trailer wheel axle grease on the post/pin top/left of my head. It's been quiet for >month.
Jabberwock
Jabberwock
Craig
Georgia
I reported the issue to the dealer when I had a loaner OB. Not sure what their official means of reporting the issue to Ford is though. I agree things like this need to be passed on.
