Software update error message on PCM-23.11.02 - Not Completed
Rus-T
Rusty
FL
Ford Bronco Black Diamond
I haven’t received an OTA in years. I’ve tried everything to get it to. I tried a few things today, did a master reset in sync and now my pass app is disconnected from the vehicle and won’t reconnect. My connectivity toggle is turned off and won’t turn back on in settings. Auto update has been grayed out for a few years now. I do have the pro cal tune.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Oh, that sounds like a completely different issue. Message me the VIN and I'll poke around to see if I see anything helpful. Many job 1 2021 Ford vehicles had an issue that got them stuck and unable to turn on auto updates. I would not have done the master reset if the Ford app was working for that same reason, but too late now.
Rus-T
Rusty
FL
I appreciate it! DM sent.I had a feeling when I did it, it was wrong
TheKim
Kim
Haha, my Sync has been unable to install the "audio optimizations" for a few weeks.
I'll probably factory reset the head unit and see if that does the trick.
consultadrone
2024 Bronco Raptor
Well I suppose I will chime in. I have not received any updates in well over a year. Ford tech support shows nothing updated in at least 180 days (evitdently, that's as far back as they can see). Last attempt was the PCM update from a while back. I figured it failed due to the Procal tune being installed. Yup, I have the ProCal tune.
I tried working with Ford tech support to reset modems, etc to try and get OTA updates going again, but no joy.
I recently moved to Utah and my navigation is so out of date, it doesn't even know my house is on a road. So, I need some updates. I have a service appointment scheduled for tomorrow to apply the various outstanding recalls (2 of them currently) as well as any additional updates. I have done the following in preparation...
Updated the Procal software with the "mothership". I do not think this has produced an updated tune file. Connected to the Bronco and reverted back to stock. All of this went fine. I expect the dealership will apply a bunch of updates, and then I will reload the Procal tune afterwards.
Anything I am missing here??
rugedraw
Javier
Miami, FL
Correct.....the OTA dashboard goes back 180 days max. The OTA process is very unpredictable and unreliable. Not getting an update sent in 6 months or more does not necessarily mean there is something wrong with your truck. That's just the way it is sometimes; even if there are modules with pending updates.
I opened up a case with Ford in regards to this issue with the Procal. If you had a PCM OTA fail and it still shows in your OTA dashboard, message me the VIN so I can send it to them. @akturbo yours, too, please.
cpsocal
Quick update on me. I received the Software Update 12 - Connectivity TCU-26.2.11.3 update yesterday, and today, back to the PCM-23.11.02 Not Completed error. So I am still getting regular updates, just failing on the PCM update, which looks to be preferred for those with the ProCal Performance Tune installed.
rugedraw
Javier
Miami, FL
Fortunately, the PCM is not a module that creates a bottleneck effect preventing other updates if it does not install.
consultadrone
2024 Bronco Raptor
Wow, that PCM update is old. November of 2023. The one that failed on mine is 25.10.0.
OffRoadRaider
Chandler
911 C2S, Bronco BL
Having the same sw update issue: PCM-23.11.02 Not Completed. Have the 2.7l and the Procal was installed 9/23. The message started popping up in June. Wonder what changed in the update process in June. I have seen other updates completed during this time. Will PM the Vin to @rugedraw
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
2022 2.7 with procal. Just got the same PCM update failed yesterday. Sounds like it doesn't matter? Really don't want to update my procal as I haven't touched it since install.
consultadrone
2024 Bronco Raptor
Well, I had the dealership apply both the PCM and the APIM updates on Friday last. Pulled my Procal tune and flashed back to stock before bringing it in. Reloaded the tune after I got it back. Everything seems to be fine so far. Only real annoyance was all my media settings were blown away.
cpsocal
Yep, seems normal for the APIM update. I read in another thread that it is a major update, essentially a brand new OS and will reset all of your settings.
https://www.bronco6g.com/forum/threads/new-software-update-today.135589/#post-2848369
Hmm...
I haven't seen anything like this for my '23 yet. I do still have the older Rev-Matching, ASS memory ProCal tune. If I update the Tune, I lose that, as Ford ninja patched it out in mid-2024
If my ProCal were to disappear one day, I guess I shouldn't cry - Ford Performance did refund me the price of ProCal for the missing features. It would just be time for a different aftermarket tune, now that the PCM is cracked. I don't know that any of them have worked on implementing rev-matching, I admit I didn't like it at first but I've kind of grown fond of it. Or maybe I would just get an ass-eliminator and run untuned.
