doyleaa
Aaron
Bucks County, PA
2022 Ford Bronco
Everything you said is correct
Where are all the bolts needed to install the hard top to the body?
I have a soft top with the HT prep kit…. I am just wondering where are all the extra pieces I need to secure it down ?
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
With a hardtop. I’m not aware that they come with anything else. If you have to purchase, go with the Rocworx set.
Ashley
Ashley
Evans, GA
Kia K5
Great write-up! Thank you!
For these side brackets - If you’re keeping your soft top too (I.e. - switching between seasons) can you leave these installed with a hard top on?
Thanks!
Not sure if your supposed too but the dealership actually changed my tops for me and they left them on. I was actually wondering if I needed to take the hardtop back off and remove them or not. But so far there has been no issue with them being on.
Ashley
Ashley
Evans, GA
Kia K5
You do have to take off the side channels on the C pillars. The brackets on the top of the roll bars can stay on with the hardtop.
the dealership left mine on when they swapped out my softtop for the hardtop.
Papa Smurf
Jax, FL
Since that post I have learned the error of it. Keeping the C pillar trim on works just fine. The only side note to that is if you have done the extensive weatherstripping to the hard top to cut down on wind noise, that will interfere with the C pillar trim.
Niceface
Josh
Arrington, TN
23' Bronc, 12' Wrangler, 21 Escalade, 21 Range
Super helpful thread! Thanks OP's.
I sold off our hard top and bought a OEM soft top and ran into this exact problem.
Just ordered all the parts from Ford and they should be here on Monday. Everything except the pieces that mount closest to the tailgate. Those are still on backorder with no ETA.
Thanks again!
alexraw
alex
South Florida
Bronco / Toyota FJ Cruiser
I have had the tailgate brackets on order since August and still haven’t not received them this is crazy.
#M2DZ 78515A54C
edit*
can anyone confirm if the part number above is the bracket in this image below?
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED IMG_7574
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 6ff8f165-83de-4771-b259-d68d7e540e87
TJGMD
Tucker
Knoxville
2021 392 wrangler
Does anyone have the two tailgate latches for a soft top from a dual top bronco available? I need these 2 brackets to convert from a hard top to a soft top.
Thanks
Part number M2DZ-78515A54-C. Or (B)
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED IMG_2387
meh
23 Eruption Green Wildtrak
So if I’m buying a soft top from someone - what do I need to make sure is included in the sale? Just the window channels and the brackets? Anything else that wouldn’t come off with the top?
I assume I can order the interior access panel from ford.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Thank you again OP for this thread! I pick up my hard top today and this was useful!
I’m going to leave the C pillar trim from my soft top on based on the posts from everyone. Sounds like it doesn’t interfere. But does anyone know why Ford says to remove them before installing the hard top?
@Ducati1098 @flip
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED IMG_6864
flip
Phil
IN
www.ruxerparts.com
Fords
@Ducati1098 @flip
I don't know if it's true for later dual top models but on my '21, they made contact. Maybe the shell was just "sprung" enough from manufacturing that it would push the sides out. Take the plates off and all was good. I've run the same top on the '21, '22 and current '23, all of which were originally soft tops.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Oh snap! Thank you Flip! Doesn’t hurt me to remove them so I’ll take them off. Better safe than sorry. Did you leave the bolts in the Bronco after you removed the trim?
JCdrivesPA
JC
Allentown, PA
2024 Bronco Raptor
Hi All,
I’m desperate to find the rear cargo latch receivers and hoping someone can come in clutch, and they have these just laying around somewhere. I cannot believe how much ford is asking for these now. $1,000-$1,600 for this simple part!
https://www.fordpartsonsale.com/oem-parts/ford-receiver-m2dz78515a54d
Can anyone help? Thanks in advance!
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 1710776475408-tr
flip
Phil
IN
www.ruxerparts.com
Fords
Put them back in so I wouldn't lose. Soft top will go back on when it's time to sell.
flip
Phil
IN
www.ruxerparts.com
Fords
Hi All,
No idea what the hell that is but there's a national stop sale and nearly 160 on back order. For that price I'd almost have to believe it includes the trim panels but wouldn't rule out their pricing is way off.
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 1710779203148-yq
