Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Did you make this or buy it? where from?
Talons Garage...
I've done lots of re-enforcement like this on TJ and JKU Skids (My Wife is particularly good at bending stuff in her JKU).
Found the best thing to be 1/4" inch thick 2 inch Angle iron laid with the point up, then welded along both edges in about 4 inch stretches with a 2 inch weld between stretches...
I don't have an example in the shop right now or I'd take a picture for you...
I really thought about angle iron, might end up going that direction. I do buy my steel out the scrap pile lol.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
May 2026 changes are storage and lowered the Bronco down with 200lb Eibach rear springs. Rides is so much better with the front cranked back down to normal height.
Ford Bronco Snacktime's Broken Bronco Build PXL_20260509_191921531
Ford Bronco Snacktime's Broken Bronco Build PXL_20260426_202825828
Ford Bronco Snacktime's Broken Bronco Build PXL_20260426_204812038
Ford Bronco Snacktime's Broken Bronco Build PXL_20260426_212635265
Ford Bronco Snacktime's Broken Bronco Build PXL_20260427_232616849
Ford Bronco Snacktime's Broken Bronco Build PXL_20260503_170537605
Ford Bronco Snacktime's Broken Bronco Build PXL_20260503_192601233
cynicalrider
First gen taco
Genius. Copying this eventually.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Annual Memorial day trip report, didn't make the final destination due to multiple down trees. Ended up dispersion camping half way.
Nice 80F high during the first day, lots of mosquitoes and cold 40F low. Next day was a wonderful 70F but got windy towards the evening. By 6pm I was adding tie down ropes to the tent and packing up for a storm. Brutal night of wind and some occasional snow/hail. Very ruff night, portable heater ran on high to keep the inside of the tent warm enough for the dogs.
Ford Bronco Snacktime's Broken Bronco Build PXL_20260525_162117919
Ford Bronco Snacktime's Broken Bronco Build PXL_20260526_011746243
Ford Bronco Snacktime's Broken Bronco Build PXL_20260525_162344320
Ford Bronco Snacktime's Broken Bronco Build PXL_20260525_162123089
