Sleeping Inside 2dr - Anyone with experience?
Roger123
Roger
VA Beach, VA
Because the seats pushed forward are at a 45, I was able to gain a few inches in length for my head by stacking a Xtra blanket and pillow behind the passenger seat. This allows me to lay flat, straight not sideways, but at an incline with my head higher than my feet.
Two questions:
What is that net between the seats?
Did you thread the holes in the room bar? Mine are just empty, non-threaded holes.
BigMeatsBronco
Allan
2021 FE 2 door
Two questions:
The net is available from Ford, I think they called it a pet barrier
The holes are there, they are the seat belt-bolt holes...mine go all the way through. But they are only threaded on the inside...so I tapped the other side m10 1.5 I think.
Ford Bronco Sleeping Inside 2dr - Anyone with experience? 20220127_091825
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
Some of us dont want rear seats. And I'm not using plywood anywhere in my Bronco.
I dig that, part of my original plan was to do the rear seat delete and looked at the Goose platform. I occasionally have friends to ride with and decided to keep the seats. I have plans for a sliding platform made with T-Slot aluminum and marine plastic sheets. Just don't have a garage any longer. The Goose Gear stuff looks great, but I think I can get a platform that will slide out for sleeping and use as a table for about a third of their list. (The Goose stuff uses plywood, just really good plywood.)
Pony Collector
N.Y. Land Of Taxes
2022 Bronco
AcenTitus
Peter
MO
dblev
D avid
Clarksville, TN
2019 Tacoma TRD Off-Road
I did a search and only found one thread with some brief discussion and some measurements. But the measurements were to the folded seat, not with a seat delete and the passenger/driver seats fully forward. I'm curious if anyone has utilized something like the Goose Gear setup to successfully sleep in the back of a 2 door. I take delivery in a few weeks, otherwise I wold have gotten the tape measure out myself. Any thoughts?
https://www.goose-gear.com/products...e-for-ford-bronco-2021-present-6th-gen-2-door
Here is the answer!
https://deepsleepoverland.com/colle...EnvPHcKKraLFiAa6o6xurt981kwwOIuAaAoUyEALw_wcB
mike8675309
Minnesota
Daemione
21 2-door 7MT
My input after sleeping in mine for 2 weeks - remove the rear seats, remove the passenger seat, and then use the two rear seat bottoms to "pad" up where the passenger seat was. That'll give you an almost totally flat surface that's about 6' long. A camping pad and a yoga mat, and it was fairly comfortable. Would not recommend for couples unless the 2nd person is really small and you're both extremely frugal packers.
Ashventure
Ash
Toyota Camry
VentureBronco
CA
2022 Base Sasquatch 2-Door
Ford Bronco Sleeping Inside 2dr - Anyone with experience? 69069577432__F5D17AF4-A539-41FE-BCC5-D4EFE121E929
I
I removed the 2 rear seats, made the same 3/4” solid platform that there are tons of threads on here about. Carpeted it. Then I got a trifold 4” thick memory foam mattress mattress (cuz I’m getting older , and comfort is more of a need & priority at this point in my life 🤪)
with the passenger seat laid forward, it’s actually comfy.
my home built platform is currently not raised up… but im Thinking of raising it up about 4-5”.
I’ve slept in this configuration with me and my dog (25 lb. Mini-Aussie shepherd) for about 40+ nights. No complaints from either of us. 😜. I did it like this cuz it seemed easier than dealing with tents, and I can pop in and out of dispersed camping or camp sight spots easy.
even though the trifold mattress takes up some space, it’s less gear space overall with the gear required to be comfy in a tent for me. And waaaaay cheaper than a rooftop tent, which I thought I wanted until I realized the costs involved.
Ford Bronco Sleeping Inside 2dr - Anyone with experience? IMG_9463
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Makes me wonder if the just the passenger seat back can be removed instead of the entire seat? Then you wouldn't have to tote around the rear seat bottoms to "pad" up where the passenger seat bottom was.
VentureBronco
CA
This was the trifold mattress I got off Amazon.
No complaints from me on it, but I’m not really picky. I really like it.
bedluxury 4 Inch Tri Folding Mattress Single Bed with Storage Bag, Foldable Memory Foam Topper Portable Floor Guest Bed with Removable Bamboo Cover, Breathable Washable https://a.co/d/97KVdpY
I got the 4” Single.
VentureBronco
CA
or just use a nice storage bin type thing where the passenger seat was as a platform extension , and useful storage for gear . ?
