Shudder at 75mph?
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
I have aftermarket wheels and tires with balance beads. ~34" Toyo ATIII and Method wheels. Anyone else experiencing a high speed shudder with or without aftermarket wheels? The wheels have a much bigger than stock bore but I am using centering rings.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
loosen all the lug nuts then retighten up to the correct torque in steps using a star pattern.
what's a balance bead?
ATLBronco75
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Do you know the correct torque?
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
I wouldn't use balance beads on high mass wheels, personally. I've used them on several motorcycles with decent results, but I wouldn't use them on a heavy off-road wheel/tire.
Lcubed
l
UsA
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
i generally use 85 pound feet of torque for wheel lugs. if you have a locking lug you may want to leave it a little looser, maybe 50#ft.
buzpro
Binky
Tacoma
A. check to see if they really installed your centering rings (all 4 wheels)
B. make sure your centering rings are sized correctly
RhodeIslandRed
Joe
Northeast
www.bronco6g.com
TD5 Defenders
These would make me shudder at any speed
You need high speed grease and you'll be fine.
Kidding aside, no wobble at all on stock non-sas badlands. -at any speed.
But i have chased the death wobble on other vehicles. After many, many balances without resolution, finally upgraded all the bushings to a stiffer material and better steering stabilizer. Solved. But that was a solid front axel.
Keep us posted. Following.
JohnnyBronco
Pennsylania
X4
If you don't have wheels/tires spin balanced at 100 mph then no matter what aftermarket gizmo you add it will not be enough.
