Second Fuel Pump Failure
bgautrea
Cedar Park, TX
2007 335i BMW, 2014 Acura MDX
A few weeks ago I noticed my DTE going down quickly. I had about 80 miles DTE and within 10 minutes and 2 miles of driving the low fuel light came on. I stopped to fill up. While it should've been about 13-14 gallons at that level, only 10gal were needed to fill up. When I turned the vehicle back on the fuel gauge stayed below 1/4 tank and kept going down to near nothing and 4mi DTE. I took it out for another drive around the block and on a small trail off road and the needle started to come up.
Added a bottle of techron in case there was something dirty in the tank.
Got through that tank of gas and the same thing happened again after filling up when around 1/4 tank. Added another bottle of techron and back over some bumps and it started working again.
Then drove 2500 miles from Texas to Colorado and back, then another 500 miles in Texas. I haven't let it get below 1/4 tank until Monday when I'd just hit 1/4 tank and on fill up the same thing happened.
Brought to dealership yesterday and they've diagnosed it again today as a bad fuel pump.
Backordered part with no ETA 🤬🤬🤬
++ @Ford Motor Company
2021 Big Bend 2.7L 2dr
First fuel pump failed at 11k miles
Run premium fuel only and generally from Exxon or Shell since first replacement
Now at 25k miles.
bgautrea
bgautrea
Cedar Park, TX
HoosierDaddy
__ Eric
NW. Indiana
I like how you included all the "disclaimer" information ... never ran it past a 1/4, only Top Tier fuel , etc etc etc .... thanks to all the armchair mechanics who will find a way to blame it on you.
Don't wax that hard top either !!! LOL
25000 miles, it shouldn't go through two fuel pumps if you ran crap fuel from Mexico in it.
I got hung up on the Top Tier hoopla for a short while, but it also made me realize that every other car I've had has gone 150k+ on just regular regular fuel. No fuel issues, no carbon issues, no injector issue, no spark knock issues, no major loss of fuel mileage as they aged, etc etc etc.
Sorry about your luck.
MadMan4BamaNATL
Ray
Atlanta
Not sure the grade of gas matters when it comes to these things and in the future, when you notice a potential issue, do not drive it on trails or too far at all.
You got lucky this time in several ways. Sad to hear this is your second fuel pump failure; it’s obviously a bad part and I hope Ford has replaced this part during manufacturing and glad they’ll fix it for free for you.
If you can source an aftermarket replacement, think you should do that if you plan to keep the Bronco long term.
bgautrea
bgautrea
Cedar Park, TX
Thanks @HoosierDaddy
I'm with you... In the probably 500k miles I'd driven in previous vehicles I owned, I always ran regular unleaded from just about anywhere. BUT... The one benefit I did see with the premium gas over the last 14k miles was better MPG. I picked up between 2 and 3 MPG running the higher octane.
I agree @MadMan4BamaNATL
I was lucky. Since the first time it didn't fill up, I zeroed the trip odometer to keep an eye on the miles I got per tank so I wouldn't run out of gas. Admittedly, that wouldn't have helped if the pump burned out completely like before.
BAUS67
redneck
Central PA
Maybe someone higher up the food chain can answer this better but ................
My 08 F-150 has a fuel pump driver module on the rear crossmember that is common to fail and gets rusted fast to the crossmember so it is a pain in arse to change. I don't know if the Bronc has one, or where it is, but could it be that this is malfunctioning and cause the fuel pump failure?????
One would think the Ford techs would check this but I know how most of those "techs" are. Not ALL but MOST.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
What is the reasoning for putting the Techron in a new vehicle?
‘someone please educate me. I’ve always believed that there is no such thing as a miracle in bottle
bgautrea
bgautrea
Cedar Park, TX
In my head it was for a detergent. If for some reason the sensor or float was dirty or hanging up because of some dirty fuel. It was a long shot but I was giving it a try. 🤷🏻‍♂️
bgautrea
bgautrea
Cedar Park, TX
Ducati1098
They do have a similar module, but unlike the old F150 style, they don't have any common issues and are made differently now.
Also this failure sounds like a sending unit issue, which the fpdm has no control over. It only controls power to the pump motor.
Now at 25k miles.
ETA off backorder is 9/14/23. But it also shows that the supplier is suppose to ship 44 of them on 8/14, so maybe you'll get lucky and get it relatively soon.
Also the fuel pump for both 2 door and 4 door have recently been updated, so hopefully they've fixed whatever issues they're having with them.
bgautrea
bgautrea
Cedar Park, TX
I sure hope I'm not waiting till mid-September for the replacement. Over 1 month of it sitting waiting for a dang part will be brutal.
NJNMDoc
Southwest
Bronco Wildtrak
Hey Ducati1098-
First off, you are a wealth of information and extremely helpful. Thanks for being an incredible contributor to this forum!
Secondly- do you have any information as to when (roughly) the fuel pump was updated or if there is a separate updated parts number that has been issued? Just curious if there's anyway for anyone to tell if they have an updated unit or not.
Ducati1098
Hey Ducati1098-
Unfortunately they don’t list a date of when the part was updated/replaced (at least not anywhere I can see) I’ll ask my parts dept tomorrow and see if they have any idea how to get that information.
2 door new part number is MB3Z-9H307-Q
4 door new part number is MB3Z-9H307-R
bgautrea
bgautrea
Cedar Park, TX
LoL... Technically, this will end up being pump #3. ;)
Controller and Sender were replaced previously but not a bad plan to look at other parts in chain.
Ford Bronco Second Fuel Pump Failure 1691702281410
