Sasquatch tires PSI
jaruss01
My cluster is showing 45-47 PSI for all tires. I’ve seen as low as 43-44 depending on the temp. Owned for 6 months with 2k miles. Have not touched the tires so likely came this way from dealer if not slightly higher.
This is clearly overinflated but not sure is it makes a difference. Anyone else in this boat? Should I bother leaking out some air or will it have little to no effect on ride quality/mpg? I’ve always run tires a couple PSI higher so prevent any future forgetfulness. But not sure if the dealer overinflated too much to the point I should take action and lower it
Ts3794
Ron
Reno
Jeep
What does the door sticker say?
Is this cold (first drive of day) or driving?
my motor home can’t very 20+. Depending on outside temp, an driving
Badassbronco
Georgia
The door says 39 psi cold so I would lower it. I personally have mine at 37 just to soften the ride slightly
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I'm at 35 and it still seems too high for the rear. Unless you're hypermiling, anything over 40 is excessive.
lapazleo
2022 bronco badlands
38 psi perfect ride and handing
BroncoAZ
Mitch
I ran the same size tires on my 87 Bronco (5500# with gear and armor) and was happy with 32 PSI. I think the 39 PSI recommendation is more for fuel economy and CAFE standards than because the truck needs it.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
All new vehicles are overinflated at the factory to prevent flat spots during the lengthy shipping process. Your dealer should have lowered the pressure during the Pre-Delivery Inspection.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Mine sit at 33-34 psi cold and then can get up to as high as 38 but usually warm up to about 36-37 psi.
2.3L, 10spd - getting 18.5mpg
BlueBronco
DFW
Somewhere between 32psi - 36psi is usually the sweet spot for 33's and 35's, and that's warm, not cold. 39psi is meant to eek out the best mpg performance numbers, not the most comfortable ride.
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
Either go by the door sticker or better yet, do the chalk test for better wear accuracy.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
The door panel sticker recommends 39. Which may still be too high. But when they warm up they’ll certainly add 2-3 psi. I recently went off road and had aired down, when I aired back up I stayed at about 38-39 all the way around. Even the king trip in the highway they still showed 42ish.
Snowboarder777
Audi RS7
I am riding 35 psi cold on the Sasquatch with the BFgoodrich K02 tires and they ride perfect.
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I just lowered my PSI to 35 and the ride and handling feels better. BTW, the tire pressure on the tire itself says 35 :D
Ground_zero298
Scs michigan
I run 32-36.
