Roof Rack ideas
Nellman
Nellman
Josh
Northern California unfortunately
2007 Toyota Tundra
This is true. If ford is omitting it from certain models I doubt they sell as an accessory. They are supposedly making it work for ‘22 on all models so my money would be that’s when you can get it from the parts counter.
Ford is omitting it due to weight constraints of certain options. There is an entire thread devoted to this. Ford will sell every part of the Bronco to you. If they wouldn't, you couldn't fix broken pieces. Ford does not require you to verify you need the piece they just sell it to you.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
If you're going to go aftermarket anyway, you should look for one that doesn't mount directly to the roof but lower to the body. This will eliminate the anemic dynamic load rating.
Gobi and Rugged Ridge make this style for the JL and I'm sure there will be options for the Bronco.
broadicustomworks
Hanging Rock, North Carolina
I am getting the BL with V6 so can't get the roof rack options. I was starting to look at other options and ran into a new ARB Base Roof Rack. I like the idea of the dovetail rail around the perimeter and on each rail. The options are almost endless with this set up.
I was wondering if anyone else has seen any different Roof Rack ideas? If I am going to spend the money on a roof rack why not get something that is trying to change the game. Any other ideas?
I checked that out, pretty cool stuff.
I also like the modularity of it and will never use it to its potential. But I do like the lower profile, and ability to rearrange anything how I see fit with the dovetail rails all over it.
Even has T slot adapters for $20 a set to be able to use other manufacturer's gear with it.
Definitely on my "research further list" once I have my BL in my possession.
Another option I was considering was the whole exoskeleton style where I would be able to completely take the top off and have a functional rack. But those can be expensive, and not all of them look the best (very clunky and stand away from the vehicle pretty far).
I guess the flip side is if it hugged the contours really close it would be virtually impossible to remove the rear clamshell...decision, decisions.
VelocityBronco
E
Just an FYI, you will never be able to load out a roof rack this on the Bronco... 110 lbs. dynamic load (so while in motion). The pic below is way over that. 30-50 lbs for the rack, so you have 60-80 lbs. for cargo. I see 85 lbs just in water/fuel.
My point is, what are you going to be putting on your rack and stay within load limits?
Ford Bronco Roof Rack ideas 1613074675548
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
The smallest yakima platform weighs 55lbs. Nearly every official Ford media photo is over The 100lbs limit. Kind of a joke. I really wish they figured out a way to tie into the cage.
Ford Bronco Roof Rack ideas 8A583807-6E0B-457D-BB9B-27CA455C548D
Ford Bronco Roof Rack ideas 48ECF29F-7044-4693-9427-A395C1C0EB4C
Jpeyer
Joshua
Ohio
2017 F250 Lariat
Usually at the parts counter they match your vehicle (vin) with the part. I’m well aware as I’ve been in this game a while. Simply said if they are revamping how the roof rails attach they are not going to pump out more of these than are needed and have overstock. They will do that on the revised iteration.
VelocityBronco
E
If everything in these photos was empty (cooler, rotopaks), I think they would be within limits.
I also really love the rack on that fishing outerbanks concept. IF I do a rack at all, it will be this. I do wonder what the load limit will be with only using the back shell to attach too...
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
Nellman
Nellman
Josh
2007 Toyota Tundra
ironmike
2022 Bronco Raptor
They have disclaimers everywhere that their load ratings are *subject to vehicle manufactures load limits
I get that. But Rhino Racks in particular do not strictly rely on the roof structure alone. They have reinforced braces inside the cabin that attach to the body and roll bars, reinforcing the rack. I’m hoping they can still produce something with similar load ratings to their other platforms.
splathead
San Antonio
Honda Acord
Whichever one I decide on, would still like to be able to remove the front seat roof panels easily.
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
I have a Calmini roof rack for a 2004 Nissan Xterra. My hope is that Rhino Rack makes a backbone system for the Bronco like the one available for the JL/JLU. I'll make custom mounts to attach the rack to the backbone and make use of the forward mounting points above the windshield. I'll have to make adjustments to the rack itself to make it all work. It's a good rack and definitely worth keeping.
ironmike
2022 Bronco Raptor
I’ve been in contact with Rhino Rack, and they are definitely working on Bronco products. Like you, I’m looking forward to a Backbone-like system. Also keeping an eye on what Gobi, Frontrunner, and other companies are planning.
