Rocktrix wheels for a budget
Fortydegnorth
Jason
Kettering Ohio
2022 Big Bend 4dr, 2023 Big Bend 2dr
As much as I’d like a bronze set of Method 703’s, I can’t bring myself to pay $1800 for them. I started searching and stumbled on Rocktrix. They seem to be more for the Jeep crowd, but they have some Bronco compatible options. I prefer the RT111, but they’re offered in -12 offset only. Second choice was the RT110 and the offset was much better at +12. I have a set of 35x12.50r17 Kenda Klever R/T‘s coming this week. Hopefully they won’t have too much poke for standard flares, but I’m okay with a little. From all the reviews I’ve seen, the wheels are a bargain and come in at 25#. Hopefully they look nice once I see them in person. I used a discount code from a YouTuber to get another 5% off. No tax and free shipping as well. Thought this might help someone on a budget or for wheels they won’t mind a little rock rash for the price.
Ford Bronco Rocktrix wheels for a budget IMG_3654
Ford Bronco Rocktrix wheels for a budget IMG_3653
PWillette
Parrie
Maine
I had similar feelings on dropping a bunch of cash on wheels that'll most likely get rashed. I ended up going with Blackhorn BH01 w/ +12mm offset for about the same price as your RockTrix wheels. Going from the factory +55mm offset you will have a pretty good amount of poke beyond the non-sas flares...you are effectively pushing the wheel out 43mm (1.69")
Fortydegnorth
Fortydegnorth
Jason
Kettering Ohio
I’m okay with that. If it’s too much I swap to Sasquatch fenders.
PWillette
Parrie
Maine
If your the type that likes to keep vehicles at least semi-clean you may as well order the SAS flares now...it's fairly impressive how much spray covers the side of the truck.
bniknar
Bri
An old EcoDriver
I see that this Rocktrix is a 17x9 +12 offset.
I have a non-SAS Bronco. I’m thinking of going with Vision Warrior 375 17x8.5 +25 offset. Any idea what poke that would create? My OEM wheel is 17x7.5. Apologies I don’t understand how wheel width figures into poke calcs/offset numbers.
Fortydegnorth
Fortydegnorth
Jason
Kettering Ohio
You should be 3/4” less poke Than the Rocktrix, but a lot depends on tire size as well. These are 35x12.50. I changed to Sasquatch flares.
Ford Bronco Rocktrix wheels for a budget IMG_4190
NorseBroncman
Ted
Ohio
23 Bronco, 22 BMW
What wheel and offset is this in your picture?
