Rockslide Engineering Steps - GROUP BUY has started!
2Jeeps&PatriotX1
Denver, CO
Send a under side pic if you can
Exact same on both sides. That is the mag chloride treatment CO puts on their roads during winters covering the underside of the bronco after 1 day of driving in winter conditions.
Ford Bronco Rockslide Engineering Steps - GROUP BUY has started! 92437320-F546-4EB7-BF64-A708B9D96190
Ford Bronco Rockslide Engineering Steps - GROUP BUY has started! B6B9E60E-E5C7-425D-A590-06CF02C34149
Herbie
Alex
Cleveland OH
2022 Badlands
Gorilla tape it.
2Jeeps&PatriotX1
Denver, CO
for $2k I shouldn't have to use gorilla tape. If they wanted people to have easy access to the wiring connecting, how hard would it have been to make an access panel with 2 threaded bolt holes?
TXArea51
Juan
Lumberton
FORD Bronco Big Bend SAS
Or could of made a removable cap, haven’t got mine yet, but I might do that
Happy
Jerry
Missouri
CJ5, Wagoneer
Why does anyone need access there?
That seems a bad design. Once mine get here I don;t think I could leave it standing open.
Gorilla tape was mentioned. They make a waterproof exterior grade tape. It is tough and rubbery. It won't stand up to being repeatedly scraped by rocks but would take a few years of road salt.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
@2Jeeps&PatriotX1 Thanks for reminding me about those holes - kind of forgot about that after I had installed.
Problem solved...took some smoked plexiglass that I had and cut two "covers" for the holes. They are 2.5" square, with rounded corners, so I cut the stock to 2.5" one direction, and 4" the other way to give me 3/4" overhangs on each end for attaching.
Ford Bronco Rockslide Engineering Steps - GROUP BUY has started! IMG_7140
Then I routed the thickness down so that they would sit flush with the outside. Used my router table for the ends, and then just used a Dremel bit to round the corners down.
Ford Bronco Rockslide Engineering Steps - GROUP BUY has started! IMG_7141
Tested the fit, left them in while I drilled (so I would not catch any wires inadvertently) and screwed them in. (Also painted the holes with rustoleum for a little extra protection. didn't clean off terribly well, but not really concerned under there)
Ford Bronco Rockslide Engineering Steps - GROUP BUY has started! IMG_7142
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Man, I appreciate the effort you put in here, but I gotta say I agree with a previous post - for the price, there should at least be a rubber grommet insert or something for these holes.
buzpro
Binky
Tacoma
sorry for not reading 28 pages of comments but do these things work with the doors off?
mds5917
New Jersey
I’m not saying there shouldn’t be, but there isn’t, so I fixed my problem with stuff I had around in an hour or so.
Honestly, I really needed a project anyway. Was bored, so it was something fun to try.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Yes, with the door delete kit. You can flip the switch to manually move the steps
Herbie
Alex
Cleveland OH
2022 Badlands
Just a bit of levity sir. I have the same steps. Not quite sure what the reasoning was to the design other than the access you mentioned as well as maybe to allow adequate drainage.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Now I have to remove the badges on the steps and cover those holes. I will probably make a plate out of aluminum or stainless and use some nutserts to mount it. Lame, still excited to receive mine.​
Kaopeterson
Robert Peterson
They Finally shipped…. Hopefully will get them next week
Yep! I got tracking as well. Immediate delay in delivery date, lol. But I have tracking, so I’ll take it. Too bad I’m not going to be able to have time now for a couple more weeks with other things going on. But can’t wait to tackle and got an RTR grille ordered as well that I’ve been waiting to be able to order for months, so a couple projects to knock out.
Kaopeterson
Robert Peterson
If you get the additional slider portion, does that cover it up maybe? I’m a little annoyed we have to buy the slider portion separately as the whole reason I really bought these was I thought the were slider/steps in one.
Happy
Jerry
Missouri
CJ5, Wagoneer
I've asked about this a couple different ways. The answer that came back is that the steps will slide and are pretty rugged. They will protect your body if you contact a ledge or rock. The standard step seems made to be enough protection for us who go driving out on trails and just might hit a rock.
The extra bolts on pieces are for people who take their vehicle rock crawling and knowingly plan on sliding on rocks as part of their adventure.
We shall see.
